Off topic - IHC skid steer loader
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Off topic - IHC skid steer loader
    Posted: 21 Feb 2016 at 12:05am
I've got an old IHC 3300B skid steer loader with a bad loader hydraulic pump.  I've spent hours searching the internet for information or parts for it, haven't come up with anything yet.  The pump is a TRW H, IH # 68576 - C91  190.  What seems to make it unique is it has a tapered drive shaft with a key for the gear.  Got a pump at Surplus Center a few years ago but it has a straight shaft.  Might be able to somehow grind out the gear but wouldn't be easy.  Probably too hard to do in a lathe.   Any Ideas?
Allis Express participant
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 1:27pm
I would sure think that as big as Denver is, someplace there would be able to help ya out. A generic hydraulic shop ought to be able to fix you up. I (actually my wife) just bought an IHC skid loader, model 3200 A, and I hope we don't get to having trouble finding parts. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 4:51pm
I replaced a pump on a New Holland skid steer - found the same pump with a different shaft - (NH had lock on the shaft for mfg rights) just replaced rotor , housing and everything but shaft with second pump parts - 1/4 price of NH unit.
 Same with some valves that went into control - NH was $250 + and so called non serviceable - units I got were $70 and used a snap ring retainer for internal parts where NH had a swedged permanent closure which made service impossible .
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 6:35pm
did IHC make their own or was it re-badged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 7:33pm
I doubt the bore of the gear is hard. If you can score it with a file, you can bore it on a lathe. If it is hard, I have rigged a die grinder in a lathe to use as an ID grinder.
