WD45 brake pins
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Topic: WD45 brake pins
    Posted: 04 May 2010 at 5:43pm
I know there is a forum posted on brake pins already. I would just like to thank anyone/everyone whos giving information and to making this forum/page operate. You all have excellent veiws and opinions so I say thank you and this is my story.
     I've been working on freeing my brake pins for 2 weeks now. I just got one to move 1/16". I have the pin taped for a 7/16" bolt and a socket as a puller. I have a long journy ahead and one complete side to still get freed. Doesnt help the tractor was sitting outside under a tree for 19+ years.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:49pm
I removed the brake covers and sprayed KROIL down there good [ blow out debris 1st]. Soak from outside also. Keep applying Kroil every 2 day's or so, I buy Kroil by Gal, best price and it works!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:51pm
Oh boy - this sounds like fun! I expect that I may have this to look forward to on the WD45 (pix tomorrow) that followed my home tonight....
WC, CA, D14, WD45
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:51pm
One thing to keep in mind is that the old brake linings usually had asbestos in them. Be careful when blowing the crud out especially if it is really powdery and dusty. Might not hurt to at least wear a dust mask!
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:20pm
Another point to think about as well, the pin goes through the front and rear brake shoe. Because of the dirt, varmit leftovers, and whatever else lived in there, the pins could be rusted to the shoes. I had that on one side of my 45. Had to clean what I could out the bottom hole, and then soak over a week or so with slick'em. After about a 2 hour battle of in and out, the pin came free. Lucked out on the other side, pulled right out. Success! Good luck, those pins are stubborn.
1954 WD45 NF "Iron Tater"
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:28pm
Dang John, why didn't you say that last week?LOL! I just pulled the brake pins and brakes off of my C. I didn't even think about the asbestos lining when I was blowing out the mouse turds, brake lining flakes, rust, dirt, grease, and lord knows what else. I really should have been wearing a mask anyway, but I just didn't think about it. Good advice for everybody. I feel for ya'll with the WD brake pins. B/C pins aren't that bad, but they aren't easy either. Harder to get the brake shoes out of the housing than getting the pins out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:45pm
In each axle housing I had a nest and acorns. I shop vacced everything out not to make much dust. I do see I have rust built up on the pin inside the housing and imagine the shoes are rusted to the pins. Where I work we use "THRUST" penetrant oil. I think this product is awesome. Anyone have experience with that product??
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 12:48am
Is their any advantage to making new pins out of another material?  stainless with a threaded end or steel threaded plus with a larger knob for puller to grab. I do not really want to put the same back in, even though I will never change them again.(barring tough plowing)
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 6:22am
Here is a nice page with lots of INFO on the danged old brake pins in the WD/ WD45.
Don
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:31am
I had a real tight one last week, huge mouse nest in the housing.  I finally had to cut it out with the blue wrench-which is always a messy job, but it wasnt gonna budge.  I keep a couple of spare pins around most of the time.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 2:21pm
Pins can be made from 3/4 cold rolled stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 2:52pm
Seems like someone makes a brake pin puller. Can't remember the guy's name right off.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 3:00pm
I have never messed with brake pins,but why not make them out of a piece of 4130 chrome moly tubing,square the outer end,then cut threads on the inside,thread in a bolt and pull it out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:22pm
Thought I would be smart and use my impact to jar the pin with using the 7/16" bolt and a socket as the puller. I moved it 1/8" today but still not the results desired. I wont have time to work on it tomorrow for I have ASE testing.
