Wd45 heads
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 heads
    Posted: 20 Feb 2016 at 7:12pm
Hello guy I have a question did the wd45's have different head options?
I got a head off Ebay  it said it was from a wd45 but it's different than the one on mine.
It's shorter I think it's from a Wd can I use a Wd head on a Wd45?
I do have the rocker arms that go with it any help would be great thanks.
Some one put valve seats in my head and didn't do it right the valves stick out past the head.
#3 piston has a spot where it hit the valve but the damage in min.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 7:16pm
Most WD's used the short head.  The last year or so of WD production switched to the tall head.  If you have rocker stands, head studs, and a valve cover to work with the short head, it'd be ok to use.
AaronSEIA
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 7:46pm
You say the valve seats are in wrong and the valves are sticking out past the head, do they look like this head? If they do then you are OK using your head.
Edited by Don(MO) - 21 Feb 2016 at 7:19am
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 8:17pm
here's another angle to supplement Don's pic, the valve heads are not recessed in head. The mark on your piston is another story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 8:25pm
If you installed new pistons, do you have the part number or a pic of the pistons installed in the block you can post so we can see how high they come, I am asking all of this because I'm thinking you might have installed WD pistons and not WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 8:32pm
Thanks for the help guys I haven't replaced the pistons.
They are power crater pistons so they are right.
The reason I think the valves are wrong is because the intake valves are flush but the exhaust valve's stick out .
And they pinned the new seats in really badly they even marked one of the seats with a punch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 8:47pm
Bill it's good to know I'm not the last guy out there that still laps valves in. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 8:50pm
Here's the piston damage.
Here's the head see the 2 punch marks.
I'm planing to rebuild this head in the mean time I want to use the other head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 9:07pm
As dirty as that head is, I think you probably got a chunk of carbon behind the exhaust valve that held it open on an exhaust stroke and caused it to hit the piston. The impact probably knocked the carbon out and it kept on going without a problem.
.....and Don, those guys who don't lap valves just don't know what they're missing do they? As far as I'm concerned getting a nice smooth seating valve is one of the simple joys in life! LOL
Edited by Bill_MN - 20 Feb 2016 at 9:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 9:14pm
By the way the head is not dirty anymore.
And Don I did lap the valves on my other head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 11:02pm
I don't think a valve can hit a piston unless something else goes wrong.
 Unless the seats and valves are worn out, the valves should set out side of head.
 Center punch is a way to hold seats in. Not a problem.   MACK
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 6:35pm
I don't think the valve can hit the piston unless the rocker arm clearance is too tight. By the look of the valve indentation on the piston, double check that the valve head is not bent, unless you installed new valves. On a side note, those are not WD45 pistons, they are D17 or newer, so you have a little more power anyway. I have d17 pistons in my wd45 and they look exactly the same. Good luck with your engine.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 7:54am
 I have no history on this motor at all.
It ran ok with a slight miss but it was burning oil like crazy.
