7060 question
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: 7060 question
    Posted: 20 Feb 2016 at 10:23am
So I have a blow out in a hydraulic line somewhere but I need to add fluid to find it. I don't have a book for the tractor so I want sure if I was correct in thinking that I add the fluid in the hole behind the cab between the 3 point arms? Need some guidance. Thank
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 10:25am
Can you see oil in the sight glass on the left side of rear end housing? Power shift or power director trans?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 10:38am
check both places, in the cab and the sight glasses...2 different resivors
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 11:17am
Is a power director. In the cab is fine. There is nothing in the sight gauge on the rear end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 3:45pm
Then you would add oil in the rear end between the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2016 at 3:47pm
Got it figured out. Thanks for the advice guys!
