need some pricing values
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: need some pricing values
    Posted: 04 May 2010 at 4:58pm
what is the going rate for ORIGINAL 45 front wheel weights, snap coupler latches, a complete snap hitch assembly off a 45(bell end, draw bar, draw bar bail brkts, front brkt with spring.
THANKS, LArry
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:03pm
Bump...any help on front weight prices these days
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:16pm
150 to 200 dollars is what i have seen lately. I paid 100 for the sets i have bought, but that was a few years back. HTH
Luke
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 5:07am
I paid anywhere from 100-200 for the weights.  I paid 60 for a set of latches, but that I thought was a good deal.  They were just the regular style for WD45 and smaller D series without the round hole for the bar that links to two like on a D17 etc.  Last year I paid 100 for a complete snap coupler setup to put on my WD.  Hope that helps.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 5:52am
I paid $25 for a snap coupler bell assembly off ebay. A good bail I've seen at swap meets for $40 to $50. Some venders want $100 but can be found pretty easy for less. $50 to $75 for latches maybe a little less if you look hard. Drawbar bail brackets $10. Good drawbar $50. These are prices I've paid or seen. At certain auctions even less but you run into stuff like that by accident at auctions. Weights you can find for $50 each.
Wink
I am a Russian Bot
