616/620/720 rear pto function
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 rear pto function
    Posted: 17 Feb 2016 at 9:47am
Just wondering should the rear pto turn if there is no implement hooked up and you hit the switch?
Thanks
David
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 11:28am
you should turn it on id say once a month, but run it with no attachment continuous, no...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 11:50am
so you are saying turn it on to basically make sure the clutch is free, but it will not turn without an implement?
This page was generated in 0.266 seconds.
