what did they do with this front axle |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2578 |
Topic: what did they do with this front axlePosted: 16 Feb 2016 at 8:02pm |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 16 Feb 2016 at 8:11pm |
not a factory set up
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 16 Feb 2016 at 8:29pm |
Some idiot totally trashed the tractor and the blade.....
ALLIS EXPRESS!
This year: |
AJ
Posted: 16 Feb 2016 at 8:58pm |
It's factory it's just not attacked to the tractor. They took it loose and laid it forward. You can see it there on the ground out front. Front of tractor is sitting on blocks.
Can't fix stupid
Acdiesel
Posted: 16 Feb 2016 at 9:09pm |
looks narrowed.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 16 Feb 2016 at 10:30pm |
![]() ![]() ![]() ![]() I'm sure it "ran when parked" at least some time in the last 20 years or so. Still it could be worth something. The blade needs put back together if it is all there and so does the front end. Edited by CTuckerNWIL - 16 Feb 2016 at 10:31pm |
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 16 Feb 2016 at 10:34pm |
was a hard roll over!
CTuckerNWIL
Posted: 16 Feb 2016 at 11:01pm |
Kinda looks that way with the left side of the rad shroud buckled, the right side caved in and the left rear wheel gots some camber to it ![]() |
Eldon (WA)
Posted: 16 Feb 2016 at 11:12pm |
and the bent up steering wheel
ALLIS EXPRESS!
This year: |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 17 Feb 2016 at 6:18am |
Ran when parked!! LOL!
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 17 Feb 2016 at 6:45am |
Ran when parked upside down....
SHAMELESS
Posted: 17 Feb 2016 at 7:02am |
well...ya don't hafta be wearing any clothes to work!
cpg
Posted: 17 Feb 2016 at 7:48am |
But its valuable being that it's a 1935 WD, must be an experimental model.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8573 |
Posted: 17 Feb 2016 at 9:07am |
Aaahhh Yea!, this tractor has some serious issues! Rear wheels don't look aligned as mentioned. And front wheels look to have just been set there for the picture?? May have broke off the front end during roll over? Exhaust is not covered either:(
Regards, Chris |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3938 |
Posted: 17 Feb 2016 at 9:26am |
It's sitting on some concrete blocks and chunks of timber to make it look as if the front axle is attached. Looks like a hard roll over to me! Might be a good price for a parts tractor if the blade is included.
T.J.-N.J.
Posted: 17 Feb 2016 at 4:09pm |
Tires hold air till you turn your back, that looks like a treat to load up too. T.J.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 17 Feb 2016 at 4:31pm |
Wink I am a Russian Bot |
T.J.-N.J.
Posted: 17 Feb 2016 at 8:36pm |
Personally I think it went off the side of a trailer.
Dswall
Joined: 11 Jan 2014 Location: Lindsay ca Points: 260 |
Posted: 17 Feb 2016 at 10:34pm |
It Had a bad day!!
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 18 Feb 2016 at 6:42am |
Looking at the 3rd pic, front axle looks like it was tore off. Missing the pin on the back of the wishbone, and the wishbone looks bent.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
