Quadrant bushing? |
Post Reply ![]() |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8591 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Feb 2016 at 7:43pm |
Floppy steering shaft(WD45).A remnant of some kinda bushing in the quadrant hole and of course the shaft is knecked down where it goes through the hole.Parts book lists "bushing" under quadrant but no picture.Guessing they had one? The hole is a loose 1in bore and shft is supposed to be 7/8. Any one have experience here?
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Here's what I did on a WD. Went to Fleet Farm and picked up a flanged brass bushing that was 7/8" inside and 1" outside diameter. Of course, the shaft and hole are worn a bit, so it should slide right in. The hitch in my giddyup was I couldn't get the steering wheel off. So, I cut the bushing in half, coated it in grease, put the two halves in. Then put a hose clamp on the shaft just above it to keep the pieces from walking out. Correct? NO. Functional? YES.
![]() Just a thought. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Looks good
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Drive the pin out at ujoint and pull shaft and wheel to gather. MACK
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3042 |
Steiners sells the bushings, but you can probably find cheaper from someone else. Like MAC said, pull the steering wheel and shaft, then tap in the new bushing.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8469 |
Yes had to repair this on two of the three WD's. pulling the shaft and steering wheel is probably the easiest. Then you can put a bushing in there. Might need to do some work on the quadrant?
BTW the steering wheel to shaft is generally grow'ed together. If the wheel is not going to be replaced. No need to try to pull it. Most steering wheels have to be cut off the shaft if you are going to replace them. I have not had luck trying to pull them. Regards, Chris |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Replaced mine also. Got the part from Sandy Lake. Getting the wheel off was the tough part. Mine required a good beating plus a bearing puller.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2296 |
When I did mine the shaft was worn bad too so I just got a new piece of shaft and replaced that too, was a lot easier than building up the old shaft and then could just cut the old shaft out of the steering wheel. Was able to get steering wheel redone at that time too, don't know of anyone who does steering wheel rebuild anymore.
Adding charr-lynn ps.Junk wheel came with shaft cut to fit.Needed to switch wheels.Lightly drill peened end of pin through hub and drive out with punch.Set wheel/shaft in press and push.Niether one gave much resistance.A puller would have done it easily.Just my experience.
Post Reply ![]() |
