ac 190 cab
jdodds79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Topic: ac 190 cab
    Posted: 08 Feb 2016 at 10:20pm
Im looking for a cab for a 190. Im located in northeast oklahoma but willing to travel for the right deal. Thank you
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 11:01pm
What kind of cab are you looking for?
I have a few cabs
Andy
4026404518
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 11:02pm
I have a few cabs
Andy
4026404518
Andrew Gubbels
Gubbels Restoration
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 11:56pm
did any of the 190's come out with the factory cabs like the 200's?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 4:14am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 9:46am
Yes, they were made by a company called Stolper Industries.  I don't think it can be considered a factory cab since it was not made by AC.  200 Cabs were made in LaPorte by AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 10:11am
7060...them cab doors were pants rippers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 11:50am
Just a cab, air would be a plus but i can do that later. What do you have? Where are you located and how much? Thank you in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 2:02pm
Yeah Shameless. I've never seen one of these in person. They scream "much to be desired". However, if it was raining or worse, cold snow blowing, they'd be very welcomed... I remember loving the heat blowing back on me from the engine in a heat houser though :)
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 9:33pm
I have a Full Vision cab from a 190. It has the folding doors on both sides instead of the swing out door. All glass there. 1 or 2 may be cracked. Has blower fan. I was going to install an under dash air, but bought a 200 with cab. $100 I'll try to get a photo.
I also have one for a D19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 9:39pm
Where are you located?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 9:54pm
we have that split door cab on our 200 for now!!!!!!!!  yea its a real pain in the ###
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 10:32am
According to Norm Swinford's book, "Allis-Chalmers Farm Equipment 1914-1985," AC started working with Stolper Industries, Menomonee Falls, WI back in 1965. Stolper designed the split-door cab shown above. First tractor with Factory-installed air-conditioning was a One-Ninety serial # 10962, in May 1965.
Interesting note about the split-door cab photos above. If you view the close-up of the split-door, you'll notice how the rear angle of the door matches earlier One-Ninety series I's sloped rear fenders. I think the tractor in the photo is a series III?  It's newer Stolper cab's split-door angle remained the same as earlier versions. However, Stolper (or AC?) added a metal extension that matched up to the Series III's newer flat-top 2 light fender.  This newer Stolper Cab has the double headlights per side, accompanied by upper brows. The older Stolper cabs had just 1 headlight per side bolted to front of cab without any upper brows.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 10:49am
Although it was made by Stolper and not manufactured by AC, I would still consider it a "factory" cab as they arrived from West Allis, Wisconsin, from the factory, with the cab already installed. I don't believe they were installed by the dealer at all. At least I don't remember any done that way. Just my two cents...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 8:19pm
Weatherford TX
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 8:51pm
Any idea on shipping to tulsa area? Does it all come apart to flat pieces you can stack flat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 11:03pm
the frame prolly doesn't come apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdodds79 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 11:41am
I sent you a pm joe
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 3:50pm
I looked at a new 190xt in 1971, the split door cab really wasn't much worse than any other factory cabs of that time, I thought it was nice cause was going to be our first cab tractor.  Had a heater in it too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 5:53pm
I got a picture of the cab.
It can be disassembled with a lot of work. I did it on the D19. I really don't want to do it again.
I would prefer pickup because it would be difficult for me to ship.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2016 at 9:13am
JoeTX, thanks for sharing a picture if your full vision cab. Just to verify, does it's doors fold inward as they slide forward?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2016 at 9:58am
that cab sure looks familiar
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 12:32pm
My 190 has the Stopler Cab. Interesting the Clutch pedal has to be cut in half for the door to have enough clearance when opening in.
I am looking for a window rubber striping kit for it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 12:37pm
http://www.harris-stolper.com/
Stopler is still in business
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 5:13pm
Yeah, you've seen it before
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 5:14pm
They fold out
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 6:42pm
We had a cab just like that on an early 190 diesel. Does it have the 2 small oval windows on the back? I would like to get one just for the memories but then I'd also need to get an early 190 to put it on which im hoping to do some day. They're actually pretty hard to find.
Renoron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Renoron Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 3:32am
I see this thread is 4 years old. I have this same cab with the split doors mounted on my Farmall 706. Doors were trimmed at the bottom. But, wouldn't take much fix back original. If interested, PM me. I'd really like to find a cab for the Farmall. Thx, Ron
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 7:05am
I agree. Deere did the same thing for the 4020 using Stolper cabs and later Hinson cabs and they're considered a factory cab. Crenlo was building the Sound-Gard cabs for Deere at one point.... though they were Deere designed vs the non-Deere designed Stolper or Hinson cabs.
Wink
I am a Russian Bot
Bob J (Wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J (Wi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 8:08am
I have a Cozy Cab off of my 200. It has a heater. I am not using  it. I can send a pic if you are interested. IF you come and get it out of my garage you have it for free. I am north of
Green Bay Wi.
This page was generated in 0.273 seconds.
