Starter heater on GM diesel - HD7
Karanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Topic: Starter heater on GM diesel - HD7
    Posted: 08 Feb 2016 at 1:56am
Can anyone help me with parts or info on the heaters fitted to HD7 and other allis crawlers
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 7:35am
Most of them have ether inject system and some had diesel fuel heater option. What are you needing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 8:00am
Hello, my hd7 has the coil type where diesel is sprayed onto a spark which is generated my the coil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 8:35am
Never seen such a device, photos of the old?  I have seen air intake heaters, look like a sparkplug but have a heat coil rather than a gap and no ignition coil to pop it.  Most of those did not work all that well and have long been discontinued where a ether spray in the intake works batter for firing chamber heating during a starting roll.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 12:22pm
Can't get my pics loaded up of the heater which is a pain
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 12:28pm
D Miller it is the one with the spark plug ignitor in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 12:39pm
Yes, it's sparks then diesel is sprayed over it to flame it
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 1:25pm
i found this info.  not sure what you are needing
Heater operation for M1 Tractor (military HD10)  pdf starting pg 18.
also these parts book pics from HD5 with heater similiar to what you should have
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 1:45pm
All the parts are the same but it looks like it's fitted different to on my hd7.
Would like parts from the last page which is part 4 and 7.
1115485 ignition coil
5569546 insulator assembly
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 1:53pm
how did that little canister thing on the dash with a cap and chain on it work. I have never seen it used
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 2:01pm
Not sure what chain you are talking about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 2:01pm
gotta love google.   according to google searching.    those are GM part #'s and I found interchange #'s  maby something still available
cap and chain cannister was for ether capsules..  before bottle or can spray systems
Im guessing near impossible to find insulator piece, but maby a modern coil could be fitted to work.
Edited by CAL(KS) - 08 Feb 2016 at 2:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karanger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 2:17pm
The coil has build in points on the top so it's hard to find a stand in coil that you could easy make fit
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 3:07pm
A rubber ball containing ether is put in the canister. When the top is installed the ball is punctured. The dash mounted injector is pumped to move the ether to the intake manifold. I had an HD7 with this system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 3:57pm
thanks dozer I had no idea I use to think the used carbide or something . I guess the spray cans took the place of it
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 6:06pm
Those ether systems were used on other AC gear - the 45 graders had a similar system.  And the manuals suggest the capsule was gelatine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 9:13pm
I think i saw a can a while back that looked like a old school brake fluid metal can with screw top that was empty that said something like surefire on it i bet that is what came in that .
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 9:16pm
I have heard some old guys talking about taking some carbide and spitting on it and sticking it next to the air breather to start diesels back in the day
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 11:15pm
That was the first way they sold it. Uncle talked of putting a little in pump oil can and spray down the intake. But would evaporate out of oil can,so put unused part back in screw top can and close it good and tight. Capsules were the next to keep them from evaporating,were ok if you had the set up to us them.
He said once someone saw the spray cans everything else was forgotten very soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2016 at 6:37am
Carbide rock makes acetylene gas when wet, we use it for killing moles by dropping down in their runs GASSEM!!
Would be interesting as to setting a fire in a Detroit intake, never considered it was done, did use gasoline in a squirt oil can when can ether or capsules was unavailable, just have to be light touch to the trigger.  Gas on a rag does almost as well just need two people.
