WD 45 won't stay in 4th
Kevin NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin NE Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 won't stay in 4th
    Posted: 03 May 2010 at 7:02am
Bought a 45 on a sale last winter. Guy said it jumps out of 4th gear, but it won't stay in at all. Have to hold it in all the time, load or no load. Haven't had the cover off the transmission yet. Any thoughts? Fork or gear? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 7:46am
First off, every time you use 4th and it pops out you can only make it worse. You could pull the shifter and see if the bottom end is wore out, but more than likely it is the shift collar and the splines on the gear are rounded off too much. If you have slop fore and aft in the trans gears you will need to address that. I'll bet you have to disassemble the rear end to fix it. Drain the tranny and rear end, remove back wheels and final drives, pull back cover of, remove shift tower, remove ring gear and pull the pinion shaft out catching all gears and collars as it comes apart. If you freeze the pinion shaft before reassembly, and you work fast, you can get the tranny back together fast enough to push the pinion into the rear bearing.
Good luck,a repair manual will almost be a necessity.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 9:22am
Charlie is spot on, You need to get the top off and look inside before we can help more.
Don
