D19 right side panel
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: D19 right side panel
    Posted: 28 Jan 2016 at 7:00pm
I have a right side panel to install under the gas tank but it will not work unless I cut it. There is an oil filter assembly mounted in the way. The side panel on another D19 is cut to allow room for the oil filter assembly. Was there a change made where the filter was added?
This is a gas tractor if that makes a difference.
Thanks in advance
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 7:58pm
  A D-17 SERIES 3 WILL ALSO FIT  THE 2 PC. UNIT WE SOLD BOTH
