Wd advice
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Topic: Wd advice
    Posted: 27 Jan 2016 at 11:22am
Hi guys I'm looking to buy my second tractor I'm looking at a allis Wd.
http://ottumwa.craigslist.org/grd/5416445804.htm
Is this a good price?
Any help would be great thanks.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 11:46am
While it's a little ugly it says runs and drives. Tires appear round. I've always maintained that a running working tractor is worth at least a thousand dollars. For five hundered I think your getting a deal. Give it a tune up chasing all the fluids and use it till your comfortable with the condition before investing in paint or upgrades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 11:46am
CAn't tell much from one picture. It could be a bargain if everything works as it should and the rear rims aren't rusted out, but it could be a money pit too if sompin isn't right and you start fixinn things as you go.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 11:49am
If it runs and you can drive it to test the hand clutch and all the gears then the price is good.  Also the curved shifter may indicate that this is a WD45 which gives it more power than just the WD.  If it can't be started then you must assume nothing works and I would not give more than $200-300 for it.  Good luck.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 12:43pm
If your in it for a challenge! Buy it! If it runs and moves go for it! Then get the check book out! Headlights, figure the fenders are rotten where they attach, all the oils are shot and will need to be flushed out a few times. Hope the block isn't cracked... But can always part out and recoup 500 bucks! Ask about implements looks like an old AC farm! May score big! Good luck, I'm enjoying the heck out of my WD project!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 1:31pm
even the one behind it has a can on the exhaust, so if they care enough to do that, there is some  hope...
JakeWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JakeWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 2:01pm
Says it runs and drives ,sheetmetal looks not to bad I would go for it at that price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 2:08pm
Thanks for the advice I'll let you know what the guy says.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 4:15pm
The price is not toooooo bad. Assuming the tires are ok as is. I paid almost that much for a WD with stuck engine. Just depends how bad you want it? Might be a 45 which is a little more desirable. More pictures would help too.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 5:11pm
Check the oil make sure no antifreeze in it.
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 6:33pm
Pull the dipstick if the bottom is rusty that means it's been sitting with water in the oil pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 6:38pm
Thanks guys still waiting to hear back.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 10:28pm
If the rear rims are both good, you can't go wrong for $500. The rear rims alone are worth half the asking price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 5:24pm
Well I missed out on that one it's sold.Cry
There is another one here.
http://desmoines.craigslist.org/grd/5421389659.html
The only thing I'm worried a bought is that tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 6:31pm
It looks like it will need tires all the way around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 7:11pm
This one has potential. Yes you will need some tires.
Again about what I paid for one and it didn't run and had bad tires too. So even if they gave it to you you could put $2000 into it pretty easy.
Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 6:10am
Kind of hard not to go for it for $500.  I'd still offer 4 and see what happens. Or even start off with $300 saying the tires, fenders, lights, lift arm latches....anything else that is bad/missing.  MAKE SURE it runs though... Have HIM start it for you.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 12:45pm
If you buy it, it will keep me from buying it. I really don't need another project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 2:09pm
I got a hold of the guy I'm going to talk to him tonight after work wish me good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 5:31pm
I called on it It's a wd45 some where in the fifty's.
It dies burn some oil Ill check it before I buy it.
I'm going on Sunday but he said a lot of people have called so it I might not get it after all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 7:52pm
Good luck,
Not sure that left tire is going to be able to be saved? Some folks may shy away for that reason. Calls don't buy the item. Parts are readily available for the 45.
 I have seen worse.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2016 at 7:56pm
Almost anybody selling something will say they've had lots of calls and lots of people interested in whatever it is they have but yet there it is still for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2016 at 6:22pm
Tomorrow I'm going to  check it out I'll let you know what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2016 at 6:44pm
A WD45 for $500 bucks and it runs? Don't dilly-dally. I think that's a pretty good price even if it may need tires. If yer' lookin' for a neat project Tractor, there it is! Stick some air in the tire and get it up on a Trailer and git' it home!  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2016 at 7:06pm
My advice...Just make sure it will run for a while...not just for a few seconds and that is has some power and it doesn't smoke !!! I bought a tractor once,...it did not run too good,, the seller said "it just needs some carb cleaner and it will run ok"""" I believed him..what I should of said was if that is all it needs why didn't you do that before I came and got it running right! Learned a lesson there!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2016 at 10:31pm
David there are better ones around here, unless you are desperate for one, don't be in a hurry. Pick up The Exchange, local shopper that goes over the bottom 1/2 of Iowa and a lot of Missouri. More of them in there are being sold by retired farmers or the widows or sons and daughters that don't have a need for dads old tractor. . Most of them would have been taken care of in their working days, as the owners dependaded on them to make a living.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 3:53pm
I  got it!!!Tongue
It runs fine just needs a tune up and a little maintenance.
It's  a wd45 it's 1955 I think.
I'll post some pic's later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 3:58pm
Congratulations! Looking forward to the pictures too! Running tractor! Awesome.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 4:06pm
Congratulations!!! Looks pretty good I think!
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 4:44pm
Edited by what66 - 31 Jan 2016 at 4:45pm
This page was generated in 0.343 seconds.
