stub shaft for wd
bus7 kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bus7 kevin Quote  Post ReplyReply Direct Link To This Post Topic: stub shaft for wd
    Posted: 01 May 2010 at 11:55am
looking for a stub shaft for wd. complete with bearings would be great. the closer to scf wis. the better. i'm not sure its called a stub shaft but its the short little shaft on the right rear axle.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 12:43pm
i would have a axle for a wd, used. call if interested, im in minnesota by rochester, 507 421 0213
This page was generated in 0.110 seconds.
