panky's Hi Perf Distributor
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: panky's Hi Perf Distributor
    Posted: 01 May 2010 at 9:52am
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 10:00am
the first picture is the engine the distributor is going on isnt the rockers purty last picture shows the depth . you probably cant see that its correct but you can see that it doesnt block the gear and the shaft. 3rd picture gives a idea of how much bigger the cap is than the stock cap setting on it.  The mason jar holds it up . Alot of enginenudity comes out of it. hudsonator my jar is full.
operators are standing by the phone  to take orders .will ts me setting by to lazy to stand all day.
Edited by mlpankey - 01 May 2010 at 10:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 12:43pm
Pankey, both the water outlets on top are closed off.  Is that temporary or what do you do to circulate back to the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 1:10pm
  Chuck if you notice the casting plug in the front center of the head is tapped for 1/2 pipe thread so is the one in the back water will be pumped into the rear of the head and return to  the radiator from the front of the head. Theys a aluminum plate now where the water pump goes also. Block is dry water wouldnt pass around the 5 inch od sleeve that is in the block.
Edited by mlpankey - 01 May 2010 at 1:13pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 1:46pm
-must be a prototype.  When will a working unit be available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 2:04pm
I was hoping to have it complete today but my sinuses have the better of me today.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 2:15pm
For those of us in the cheap seats, whats the advantage of doing what you're doing to the dist?  I get the roller rockers, etc.  The massive dist has me confused.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 2:52pm
AaronSEIA
the explanation is in this post from yesterday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:33pm
Thanks.  I love reading your posts about the pulling side of engine work.  The electronic stuff still mystifes me, but I'm getting there.
AaronSEIA
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:14pm
Originally posted by mlpankey mlpankey wrote:
  The mason jar holds it up ...... Alot of enginenudity comes out of it. hudsonator my jar is full.
operators are standing by the phone  to take orders ..
Mason jars and enginenudity, must be a Tennessee thing.
Taking orders on what?  Distributors or Mason Jars?
I like the HEI distributors, if for nothing else you can tailor the mechanical curves without disassembling the whole distributor.  I have a bunch of vega/chevette HEI housings hoarded up, they're shorter than the 6&8 bangers.  I don't intend to use them on an Allis - but will eventually find their way onto a maximized flathead 6.  I wouldn't have thought ionization would have been a problem on a slow turning tractor - must be all that CD shenanagans created by the MSD box.  I completely understand the pole distance in such a case.  By the time you get the HEI voltage up to par with an appropriate A/F ratio in the cylinder, you won't even need the MSD box anymore - isn't that some irony?
Edited by Hudsonator - 01 May 2010 at 5:15pm
There isn't much a WC can't do.
WD's just do it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:20pm
I have my doubts about the hei being better than the 7 al2 box especially on a 15.1 compression ratio. I do think its a honest up grade better than petronix hall effect switch where the rules state electronic ignition is allowed but no ignition boxes. Its the closet way to get msd 6 box  mjoules of spark without the 6 box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:40pm
I hope you have been a student of Larry Widmer's "soft combustion chamber" with a compression of 15:1.  Or, you're bleeding enough with your cam to keep your dynamic compression lower.
I'm really diggin' those rocker arms!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:53pm
No sharp edges everything has ben rounded .cam has overlap and the way we degreed it in made it have a huge centerline on the exhaust. Its just a matter of changing a degree key if it needs moved back closer to straight up . the clear fuel loves 15 to one compression.  the rocker arms are purty aint they murphy did a good job on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:58pm
Ahhh, so the engine will be running on mountain spring water.
That's enginenudity - is it legal?  Complain to Obama if its not, you're promoting green energy.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 2:49am
pankey if you dont mind saying ,how much horsepower is this motor going to make roughly?whats it in, wc ,45?how many rpms ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 8:35am
well kurt hamil living and jt richardson who passed a year or so ago claims to have made 160 to 175 horses with the cubic inches of this motor . I am hoping to hit 200 mark but i doubt it with the airflow numbers the head produces . that engine pictured was a 1990 natpa points winning motor before i got a hold of it. Tarbill had water issues with it and pretty much ruined all the parts with silicon glass. Rpms I dont know what this big motor will be capable of but we lightened everything except the flywheel to give it a chance higher rpms. wd 45 is the tractor it will be going into.
Edited by mlpankey - 02 May 2010 at 8:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 4:47pm
Distributor shafts are harden ! May have to mark them up just a little bit . Didn't take into consideration the number of drill bits and saw blades that would be consumed. Its worth it. I am going to do two more ,one for Clays d14 and one for Matt's ca. I did notice that out of four delco 111-745 that they were variances in the roundness of the noises of the cam  wheel  that breaks the points . I wonder if the guys that are refurbishing the 1111-745 distributors have a tolerance speck for the ignition shaft cam wheel? Its probably not critical for points since you adjust the point gap but the petronix shutter that fits over the cam wheel could have excessive play. Oh well its just a after thought. Something I will not have to worry about anymore since switching to the hei. The reluctor and magnet are replaceable in the hei and since there is nothing riding against it will basically it shouldn't ware.
Edited by mlpankey - 03 May 2010 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 6:34pm
Mitch, ever try "Rodman" brand drill bits? I got a set of them and they will drill through about anything. The guy that was selling them at the Iowa State Fair was drilling through a file with them in a drill press. They have some sort of really hard tip in them. The tip is hard enough to dress a grinding wheel. I had to buy a diamond wheel in order to sharpen them. The guy selling them stated he could punch 35 holes in a file with them untill it was time to sharpen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 8:30pm
Brian I would like to try a number 24 out for size.
