D17 series 1
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 1
    Posted: 17 Jan 2016 at 9:00am
 Ok guys, building a D17 puller and need to know what I can remove from inside the torque tube to reduce weight. Also how much ( or little ) oil do I have to use and if anyone has ideas or pics of pulling hitch please forward to me. Trying to get down to 4000 lbs.       Using NF, 38 rears, and the Cap Bros lite weight centers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2016 at 10:05am
Hydraulic pump needs to go. You can also remove the lube pump for the hand clutch. Use a D-15 front support and pedestal.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2016 at 4:49pm
well i best get to work to keep up with you
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2016 at 5:22pm
 Patrick, I told my " brothers " that this thing has to be completed before they could pull the 45 again.    lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2016 at 6:54am
good luck
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 9:02pm
Chuck, you can come over and help me on the series 4 when your done. I've started stripping it.
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 10:51am
How much lighter is d 15 pedastal
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 8:09am
What does one do to lube the torque tube bearings?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2016 at 6:45pm
Not sure on the oil level. Had one guy inform me that he only used 5 gal. Another claimed he used styrofoam blocks the fill in the area to limit amount of oil.  Maybe the Dr. will chime in on this. If not , I 'll have to check. This was brought up before but I've yet to find it in the "search".
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 7:22am
Run oil level by the dipstick. Use 821XL/HyTran oil at about 2 gallons capacity. Lube pump not really needed unless you intend on using the hand clutch for on-the-go shifting all the time. Bearings will get oiled just fine by the PTO gears carrying it up to them. Lube pump was most needed when slipping the clutch on a baler, etc. Have run one like this down the track for 25 plus years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 6:48pm
Another question... I've found a D15 narrow front end complete.This one has power steering. The 17 that it will be going on has power steering. Is this swap worth the weight savings?
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 7:25pm
Not sure about the weight Chuck but you can remove the cyl from the pedestal and make a plate to cover the hole, that would remove some weight and the D15 front is probably lighter to start with.
59 D17 gas nf, 66 XT 190, 69 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 9:42pm
Good to know. I haven't seen the 15 front end yet, just spoke to the owner on the phone.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 10:19pm
I have a completly rebuilt Manual steering set up for D17. It is ready to go. Bearing and seals, replace, bearing lash adjusted per service manual.  $250 plus exchange.
Can bring to Boonville Mo. swap meet March 5th
Edited by Macon Rounds - 22 Feb 2016 at 10:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 10:24pm
FYI
D15 and D17 use different splines on bolster output shaft and cordinating collar on pedistal.  They are not directly interchangable unless you change bolster and pedistal together as a unit.
Edited by Macon Rounds - 22 Feb 2016 at 10:26pm
