help
catman_140g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Topic: help
    Posted: 01 May 2010 at 9:22am
How do I get ahold of the administraitor to find out why my post was taken off ?
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 12:21pm
Go to where the headings for topics are and see where it says a "few simple rules". Under that is dstratton and click on that. He owns this web site. Hes very busy and may take a little while to get back to you.
Edited by ToddSin NY - 01 May 2010 at 12:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 12:54pm
What , where , and when ? are you sure you posted ? I know i have posted something then forgot to hit reply only to find out later I goofed.
Account Status: Active
Last Visit: Today at 9:22am
Posts: 6 [0.05 posts per day]
Find Posts: Search for posts by catman_140g Find Members Posts
Online Status: Offline
Under profile you can also search for your posts and find out information , above is what came up under your name , or part of it.
 Many features on this site some do not use or know about. Click on your name in post or another members and you can get a history by checking features on that page.
Edited by Coke-in-MN - 01 May 2010 at 1:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 1:36pm
I am glad to hear the reply's ! I joined on the 5th of Jan. Also posted a pic of my  TS-260 motor scraper . According to my e-mail's  , I had recieved 3 reply's about the pic after that on the 6th and 7th . Thank you for the help !
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 2:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 2:18pm
This is the pic I posted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 3:32pm
Looks to nice to play in the dirt with , friend had one , found many parts were the same as truck parts. so can find them outside of AC dealers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 3:57pm
What truck parts would they be ?
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:42pm
hope you get posting thing figured out, we need to see more of way cool 260.That is a MANSCRAPER,AAUGH,AAUGH!
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 10:49pm
Thank You ! I am looking for more 260 tractors
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 6:54am
Why don't you go get Fordboy's TS160, so you have a little brother to yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:20am
I would like to get more scrapers . The TS-260 I put in a 855 cummins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 7:38pm
I am looking for a sevice book on my scraper now . The one I have starts at 4001 in the serial # . Mine is 2970 serial # . I am ready to go back together and need spec's on setting it back up .
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:40pm
Nice.  Why the Front pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:34pm
Thank you for your comment   .   The pump use to be in the cowling under the seat mounted in it's own case . It was driven off of the flywheel . When I changed the engine out to the 855 I drove the pump off the crank with s short  PTO shaft . Again , Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 7:00pm
Really nice job from the looks of it.  I actually tested Fiat Allis twin engine scrapers once in coal mines.  They used the 855 at both ends if I remember right.  855 does not like overspeed much and the rear engine was prone to overspeed when you hit a bump the wheels broke loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote catman_140g Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 1:28pm
now I am looking for the hitch cap part # 179361 and the hex-cap screws . I cant get mine loose so I thought about slicing it with the torch if I can get one. Any thought's ?
BobsAc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobsAc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 6:29pm
260 was a great scraper....
