Disc sizing
shackratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Topic: Disc sizing
    Posted: 13 Jan 2016 at 4:32pm
What size disc should a AC 180 pull in a wheeled disc? I was thinking an 8' should do the trick or is it too big? Looking for advice from the Pros"   thanks sam
AC 180, TO-20, Case 580B Case 450 dozer
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 4:38pm
it should pull a 10-12 ft disc
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 4:44pm
That's good to know. Thanks wheatbreeded.. sam
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 4:54pm
should pull a 12ft easy.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 4:55pm
In the day, when that tractor was new, a 16 ft disc with 16 inch blades weighing probably 50 to 60 pounds per blade would have been kind of the norm. By comparison, we pulled 13 ft with a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 4:59pm
Thanks Guys  I am no Farmer by any means. I am just gearing up to work my land and make some deer very happy. At least until they make me happy..  Sam
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 5:06pm
I pulled a 14 ft tandem with mine pulled fine (hills)
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 7:05pm
we pull this one, I think its 12' or so with a 185. does a great job...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Sagefarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sagefarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 9:13pm
We had a 185 and pulled a 12' for years.  Wish we still had that tractor. It had a factory canopy.
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 9:17pm
jb, is that a 2300 disk?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 10:33pm
   sam welcome to the forum.you got plenty a tractor for an eight footer as has been stated.seems like the smaller dics in decent shape are getting harder to find though.good to see someone else from around here on the forum.i'm not too far from ya,out here near sunman.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 4:44am
Ac45dave yeah so I am finding out they are really hard to find. So i guess "bigger is better" is the way i will have to go. my place is an old dairy farm that got subdivided before i got to it. I am trying to buy up more of the old farm ground with some success but slow progress.
Thanks again guys.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 7:02am
We always pulled an 18' behind the 4020. Allis's are better, so an 18' should be fine.
But seriously, a 14' would be best I'd think. I don't think the Allis engineers wanted you to run duals on a 180 so I think that in soft ground you might have traction trouble with a 16'. 14' you'd probably we ok tractionwise.
Edited by Allis dave - 14 Jan 2016 at 7:03am
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 8:19am
Allis dave touched on a good point. Shackratt stated he's not a farmer so let's make sure we inform him on things like loaded tires and weights along with disc sizes. I don't know if they're required for a disc or not but it's better then him having to tell the Mrs "well they said it would work"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 10:02am
180 will safely pull a 12' disc in any soil, without working it very hard (fuel). Up to you on adding rear weight via iron or liquid ballast to prevent wheel slip in the worst conditions.
If you are thinking 8' disc as in a 3-pt., it will play with it and not give the same results as a well built 10-12' wheeled unit where you can get more weight onto the blades.
All depends what you want to do (aggressiveness of cutting/depth) and will you be plowing first?
Do you just want to "scratch in" some broadcasted seed?
Wheeled disc gives more flexibility for me as lighter sandy loam here.
Am cutting off old worn out gangs on a A-C snap coupler wheel disc that came in a package of equipment and a D15II. Hangers, bearings and blades are shot so I will buy my own pieces to assemble/hang new gangs under the A-C framework as I want more even control (level depth) when overseeding vs. 3-pt Deere 8' unit used previously.
Just buy discs you can easily source parts for . . . . .
sjerden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 11:50am
I pull a 9' with my little WD. Done so for years.
Edited by sjerden - 14 Jan 2016 at 11:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 12:46pm
Thendrix -- Thanks for the Note and your right! it all comes into play.  knowledge is power !! My Ex father-in-law was an A-C man and when I helped him I used his equipment. The ole man taught me a lot over the time we worked his farm together. I only wished i would have listened to him more and more often. Thanks for the advice guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 12:59pm
Timnearfortworth--the ground i am working has not been plowed in many years and some probably has never been plowed. I will plow the ground. I like plowing and disking afterwards. Gives me a sense of reason for planting deer food. I have about 20 acres or more that will be food plots. I would never go with a 3pt disc. I don't like the way they work the ground. I like a wheeled disc and with my small acreage an 8' to 12' will do me nicely. I am also going to be looking for a 4 bottom 14 to 16 inch plow to go along with my new setup. Bad thing is my ground is mostly clay and rocks so might break some stuff. I hope not. Thanks for the advice Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 7:36pm
Yes it is a 2300 dad bought 30 some years ago. we recently went through it and repainted it, and had new decals made etc. we bought a middle buster from a forum member and its a totally different machine now,,,Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 11:07pm
I thought it was, but wasn't sure. It is a very nice looking disk!!
Thanks for the reply!
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2016 at 9:01am
I have a 14ft light kewanee disk that would fit that tractor right good
This page was generated in 0.168 seconds.
