Another 12v conversion question |
Post Reply ![]() |
skeeters65 ![]() Orange Level ![]() Joined: 09 Jul 2015 Location: CT Points: 371 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Jan 2016 at 8:08pm |
If I convert to 12v can I convert all 3 lights on my B or do I need to buy complete new light assembly's?
Thanks |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5598 |
Yes you can. 1156 bulbs in front. You might get by with that in the rear. I have done it to our WD45's and "C", but the "C" doesn't have the factory rear light. I forget the size bulb in the WD45 taillights.
Edited by Unit3 - 11 Jan 2016 at 8:17pm |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
Unit 3 is correct. You're probably better using a 199 bulb which has a heavier filiment for vibration being your B has no suspension. The bullet light bulb in 12V would be a T90 or the little higher CP T97. HTH
Steve@B&B |
Is there just a grommet on the back of the light to put new wiring in? Or is it just a bulb swap???
Being lazy and don't want to run out to the garage. Thanks Edited by skeeters65 - 11 Jan 2016 at 8:27pm |
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
They are bayonet base bulbs. You just push and twist to remove the bulb. Put the new one in push down and twist till it locks in place.
DanC911 ![]() Orange Level ![]() ![]() Joined: 22 Jul 2014 Location: CT, USA Points: 598 |
I changed the bulb in the rear of my B to LED. I was able to find a red one in 6 volt on Superbrightleds.com.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8526 |
Lot of that going on right here today! Regards, Chris |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Steve has replacement wires for the lights. Once the bulb is out, you can snip the old wire off in the back and pull it out by the little "bead" on the inside. Slide the new piece in and solder to your wiring. |
Post Reply ![]() |
