New creeper
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Topic: New creeper
    Posted: 11 Jan 2016 at 12:10am
This is a start on my creeper #3 that I think I have a fair selection of parts to move forward on the construction of!
Garden Creeper Track
[URL=[/URL">http://s26.photobucket.com/user/SonnyReese/media/PictureL056.jpg.html][/URL]
Garden Creeper Track Corner View
[URL=[/URL">http://s26.photobucket.com/user/SonnyReese/media/PictureL055.jpg.html][/URL]
The track is just sitting on wood blocks so I could get some measuring done and see how things might fit up!---I don't have blueprints to work from,--only ideas in my head, so a LOT of testing/changing/etc. will probably be in order! thanks; ac fleet
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2016 at 4:53am
looks good so far...that's how I build a lot of things too...ideas and dementions in my head!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 1:04pm
I now have the grousers beveled and the center hole drilled and all welded to the chain.--wanted to complete one side and see how worked with hydraulic motor installed and hooked to tractor hydraulics for testing, and then if all looks ok,--- start on the second track build!----after getting both tracks operational, then I can make the main frame to mount them on and all the directional valves/hyd. pump/engine/res. etc. thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 8:35pm
Here is a pic. of the grousers welded onto the track chain, also note the beveled ends, which I hope will help let it slide sideways easer when turning!--the holes in the center of each grouser, I hope will let the dirt out and not pack up under the sprocket teeth! thanks; ac fleet
This page was generated in 0.271 seconds.
