Pics of the LOWERED B I have been working on.
 Rating: Topic Rating: 2 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: Pics of the LOWERED B I have been working on.
    Posted: 08 Jan 2016 at 10:05am
Hey guys I have been working on this B for a few months now. Thanks for answering all my questions. Your help has been greatly appreciated!!
I have been hesitant to post pics but some here have convinced me I should. Still got a long way to go but it's getting there.
I lowered the tractor by flipping the final drives and front end. Lowed the seat 2.5" and shortened the steering column 6.5", added WD fenders and brackets, painted the wheels and new rubber all around.
Lowered LED headlights
Front end before we pie cut it and re-welded it. 13.5* if I remember correct
Mocking up brake pedal angles
Filling brake lever holes in seat rails.
WD fender brackets cut and B drawbar pins welded on.
WD fender and brackets mounted to B final drives with draw bar pins as locators.
Seat rail mounting brackets welded on the final drive. (Welding cast is tough)
Edited by skeeters65 - 07 Apr 2016 at 4:48pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:39am
Now that is interesting! Thanks for sharing
Charlie
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:44am
looking good
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:52am
Another one Steve B wouldn't need a ladder for  LOL
Sorry Steve I just had to.
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 11:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 12:00pm
That is awesome! Show a photo of the front axle, I can not envision how you did that part!
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 12:20pm
I have seen this done before and have always been curious; how did you add/check the fluid in the final drives?
Post Options Post Options   Thanks (1) Thanks(1)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 12:47pm
Photo of the front end added.
Guys I have hundreds of photos. If you want to see something just ask.
Cpg,
To check final drive fluid you need to pull the pan off the bottom (what is now the top) of the drive. You can add fluid the the drain plug or do it with the pan off.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 2:18pm
NEAT!!!  I have never seen my favorite so low to the ground.
Great Job!
Good Luck!
Bill Long
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 2:36pm
Looks like she's ready for the race track or maybe the airport to pull baggage carts.
Keep up the good work.
Allis Express participant
TL12A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12A Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 2:55pm
that is excellent! Good engineering--
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:06pm
Thanks for showing the front axle!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:11pm
I like what you have done.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:26pm
That looks amazing great work.
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:31pm
That looks great. I like "different".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:36pm
Very slick. I am guessing that if you post the 100 pictures we will look at them:) I like this stuff but have never done much custom work. It sure makes a different looking tractor. Maybe AC orchard? Lets see a picture of you setting in the cockpit. Do you still get on from the left front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:48pm
Beeeutifull!
Kinda 'rat rod'
Always impressed when someone actually finishes a project, mine seem to drag on and on and on and ......
Jay
TBone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TBone Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 4:16pm
EXCELLENT work, EXCELLENT job!!!!
WOW!!!! yeah show pics!
Now all you need is a v-8! Ask Shameless where to get one. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:40pm
Shameless you know something about a V8 swap?
I'm thinking about a turbo on this motor or rebuilding it to get more RPM's.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:59pm
skeeters65, I told you to post the pics.  Some may not like it, but most do.  Nice looking tractor.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 7:47pm
Steve
Yes you did Steve. Thanks for the encouragement and kind words.
Chris,
Yes I still get on from the left front. Or it is very easy to step on the draw bar and step over the seat also.
Not sure I have any pic with me on it. I will work on that.
Edited by skeeters65 - 08 Jan 2016 at 7:49pm
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 8:30am
Low Clearance B for lawn mowing only if there is enough room for a belly mower. Work on making it shorter by about 24 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 8:48am
At the very least, post some pictures of the front and work (in progress) and some varying angles of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 9:01am
Ken I was looking at that wondering just what you could actually do with it. My uncle who helps me with the haying is getting older and having trouble getting on and off a d serries tractor I will be adding a step but thought how cool it would be if you could lower a d17 and still bale hay with it.
I still think that B looks amazing and talk about a great law mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 12:50pm
Hey Tuck!
I collected all the parts to build one of those. Mine will have a square tube axle simlar to an IB. Got all the parts. Just need to finish up all the other projects goin' on. Looks great Skeeter! What do ya mean your were hesitant to show pics. Are ya crazy? Everybody loves this stuff man!!  Even the purists would get a kick out of it I would think. Its not like the B is a super rare Tractor with over 100,000+ out there.... LOL!  Looks cool!
Steve@B&B
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 1:17pm
I am a staunch purist and I think your "low rider" is Awesome!!! You just won't be able to cultivate 2' tall corn with it LOL LOL
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 2:27pm
Crank start??? Ouch! Jack be nimble, Jack be quick, but only your "B" can fit under the limbo stick. I like your "B".
Edited by Unit3 - 09 Jan 2016 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 2:30pm
Crank start? It does have an electric starter on it.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 3:30pm
Ooooooooohhhh....... Good stuff for me here! Next time the old lady freaks cause I get a tractor part in, I can just show her this one and say "See what I COULD be doing?".
THANKS!
The mechanic always wins.
Ethan Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ethan Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 5:46pm
That's something you don't see everyday, looks good. Thumbs Up
If the women don't find you handsome, they should at least find you handy.
This page was generated in 0.095 seconds.
