D17D camshaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: D17D camshaft
    Posted: 29 Apr 2010 at 10:36pm
I still need to get a dial indicator and check the lobes, but if my cam and lifters are worn what are my options? Are new cams available?
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:07am
Pack up your worn camshaft and tappets and send them to Berry Cam Service in Lester Prairie, MN. They will come back reground, like new for about $200.
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 10:29am
are they able to build back up the lobes and grind back to factory lift or do they just find the smallest lobe and grind all to match that one, when I did my d19 I bought a reground cam and it was wore out, sent it back and used a gas cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 10:50am
You can have factory lift with a smaller base circle diameter on the lobe. Thats how higher lift cams are made. The tappet doesn't come up any higher, it just goes down farther.
This page was generated in 0.079 seconds.
