Mag question
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Topic: Mag question
    Posted: 29 Apr 2010 at 3:27pm
I have two Fairbanks Morse mags a FMJ4B  and a FMX4B will both work on AC engins ? If not what is the dif?  Thanks for the help. Mark L
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 5:51pm
They both should work. I have a 1939 Allis Chalmers B that has an FMX4B magneto on it, which was definitely a replacement as the original magneto should have been an FMJ or FMK.
The FMJ4B is what was on most of the B's and many other Allis Chalmers tractors. I can't say for sure that the FMX was actually put on an Allis Chalmers tractor from the factory. The FMX was apparently one of the last magnetos made (and therefore the most updated) before everything switched to electronic ignition. But the FMX mag should work.
I'm no expert but this is what I have gathered from asking similar questions about my mag. Hope this helps some.
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:39pm
Internally some parts are different but as a unit they are interchangeable.  I have swapped them back and forth on B's and WD's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 10:39am
Thankyou wjhon and Clay for answering. Mark
