replace old delco remmy 1111 distributor with hei
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: replace old delco remmy 1111 distributor with hei
    Posted: 29 Apr 2010 at 2:37pm
Replace old distributor and small cap with large cap hei ddistributor ready for drop in and go.$300ship to you.
Edited by mlpankey - 29 Apr 2010 at 2:38pm
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 8:52pm
Pankey, I have thought about doing that, just havn't got around to it.  What is it out of or are you welding 2 distributors together to get one.  DUI(Davis Unified Ignition) make an HEI setup for a small block ford using a FoMoCo bottom and HEI top.  Works real well.
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:11am
nope just turning one out in a lathe. I watch a inspirational film the other day that said you could have everything you desire if you help enable people to have what they desire so i thought i would try to sell some tractor parts instead of telling everyone how and what to make them out of.  So two drunks garage is open for buisness.
Edited by mlpankey - 30 Apr 2010 at 7:15am
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:20am
What will your $300 setup do that a pertronix and good coil can do, for less than half the money? Other than stick out like a sore thumb?
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:32am
I was never a fan of an HEI ignition. I am curious what the benifit is also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 8:35am
Garry reality is the petronix is a hall effect switch and has to have a coil with at least 1.5 to 2.3 ohms of resistance to keep from burning it up so does points . So youre feeding a coil with 9 volts instead of a possible 14 volts if equiped with a alternator . The hei has a true magnetic pickup and likes 14 volts so times the coils windings turns by 9 volts and see what youre spark energy is or times youre coil winding turns by 14 volts and see waht youre spark energy is. We ran into alot of troubles last year with the small cap cross arching with the msd 7 box and 50,000 volt pro coil also it was ionizing the air and creating plasma under the cap even with vent holes drilled so the bigger cap with 1 7/8 electrode spacing eliminates alot of troubles when trying to run mid 1980 ignition technology on a 50s era distributor. The hei will give you 80 to 144 mj of spark energy with no msd box just wired to a 12 volt power source.
http://www.pertronix.com/prod/ig/ignitor/default.aspx  click on the flame thrower coil and see its resistance.  Its amazing how much the ignitor 3 reseambles a four pin hei module.
Edited by mlpankey - 30 Apr 2010 at 9:11am
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:10am
MLP, Well described, alway's fun reading your post's! Talked with Steve from CT lately??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:17am
  O.K. , that was a good explanation.   At some point , an excessive amount of compression will require a hotter spark that a pertronix can provide. The issues you have with ionization and plasma under your cap, I had always thought were perhaps workplace related , too many rads or something......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 11:43am
I've heard of the DUI distributor, but HEI was never known for high rpm ability. The original Dura Spark system with a blue grommet module is very easy to hook up and has the large cap too. Hall effect is a better way to trigger, but I agree with the HEI having more available voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 11:46am
 I dont think  weve talked lately. Always time for conversation though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 11:51am
  In a tractor stock hei will get you into blowing it up rpms. Most people are swaping the dura spark box for the four pin hei modules reliabilty over the duraspark box . The ford tif module can be used to trigger points for around  30.00 dollars and would be in my opinion better than the petronix hall effect switch dueto being able to stand low resistive coils. but then the week spring design on the points cause point bounce at higher than 3000 rpms and you still have the promblem of the small cap.
Edited by mlpankey - 30 Apr 2010 at 12:26pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 3:58pm
If you're worrying about ionization under the cap, why go through all that trouble? Why not eliminate the source?
Double-ended ignition coils are available stock and aftermarket now, and can be wired in wasted-spark mode, and crank-triggered, to totally eliminate the distributor altogether.  The double-ended coils used on modern automobiles (my Jeep Cherokee is a good example) are under $40 each, and lay down a staggering spark- even moreso than the external coil used on improved EST-HEI system used on GM engines after 1991.  Back in the age of distributors, the coil's output had to be considered as a limitation, simply because the insulation capacity of the cap's void was insufficient.  I think distributors have essentially been eliminated on modern cars now, but it's certainly not a new idea-  look at Waukesha natural-gas engines from a dozen or two years ago- with Altronic 5 ignition and separate coils for each plug...
Just to clarify- the reason for a ballast resistor on an ignition coil, and on many electric fuel pumps, is so that when you're CRANKING the engine (and applied voltage is low due to the starter motor's draw), that the coil will have more than ample output to touch off the mixture.  Look at the wiring diagrams, you'll see a bypass wire going from starter solenoid direct to coil for this purpose.  Once engine has started, the ballast resistor is inserted in line to prevent the coil from melting down... it is, after all, a 9v coil running on (what is now) 14.2 volts.
And for what it's worth, EVERY transistor-fired ignition control unit, including MOSFET outputs, will impose some sort of voltage-drop and current limitation in the coil primary circuit... because they are semiconductors with P-N junctions.  Silicon PN junction is 0.6v .  This is one thing that ignition points have over transistors- there is either good contact, or poor contact, or no contact.  Running points with good contact imposes essentially no limitation on coil current, hence, higher voltage.
Edited by DaveKamp - 01 May 2010 at 4:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:04pm
granted coil packs and crank triggers are the newest technology . we tried them on a dirt track car and found that they didnt work well in dust or muddy conditions. going to the bigger cap will relieve the promblems that old style cap is just to small its pictured in the other post.
thanks for re hashing the ballast resitor or coils with resistance i thought it had been covered well in the links maybe not. http://www.allischalmers.com/new/forum/forum_posts.asp?TID=11768&title=pankys-hi-perf-distributor
Edited by mlpankey - 01 May 2010 at 4:38pm
