For Tom Yaz and the All Crop Experts!
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: For Tom Yaz and the All Crop Experts!
    Posted: 29 Apr 2010 at 6:23am
I am noticing on my 72, that the straw walker is hanging slightly lower on the bin side, right out at the end.  It has been hitting the raddle chain below it when it comes under full speed and load.  How is it supported??  I was trying to see what was loose, or broke, but can't find it.  It is probably staring me in the face and can't find it.  The other side seems to be supported fine.  Thanks for the help.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 4:09pm
   Well, I'm no expert but I'll give it a shot. The book shows it is supported by the rocker arms on the outside of the housing. I wonder if the bearings are out on the rocker arm shaft that goes threw the rack?
http://www.rumelyallis.com
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 8:20pm
I concur. Something in that area is amiss. One thought I had is perhaps the hole
 in the in the wooden grain drag rail (part #501806 ) that the shaft goes has worn itself  elongated from wear causing a settling of the bearing (part# 501047)  You can download the parts catalog here: http://www.yazallcrop.com/downloads.aspx
Edited by TomYaz - 29 Apr 2010 at 8:22pm
