hd5
jturano11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Topic: hd5
    Posted: 28 Dec 2015 at 1:55pm
I hear I can replace track adjusters on my hd5 with hyd ones,anyone know where to order them or anything about it?
     Thanx
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2015 at 9:33am
look here
they also mfg new sprocket rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 12:24am
Awsome,can't thank you enough.while I go the tracks apart I'll have to fix a final drive leak.any ideas of where to buy the seals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 12:29am
I can tell just by the looks of things it's going to be a not so easy job I'll have to post something for some advice I never replaced these seals before I keep losing oil from left side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 8:31am
if anyone has the parts new http://www.minnpar.com  will.  otherwise you may have to get good used.   can also view parts books on their site
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 11:17am
I have some new ring seals and boots ass for outboard bearing and should have some boot ass spring  for the rear sprocket
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 1:57pm
Before  removed the track for changing the seals make sure  the big nut on sprocket shaft is't loose
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 3:50pm
to change the seals you will need to drop truck frame from machine as well as disassemble outboard bearing on the truck frame that supports the axle shaft .
 Some work is involved in the full process - check archived posts in this section for info .
This page was generated in 0.676 seconds.
