Briggs won"t fire
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Briggs won"t fire
    Posted: 23 Dec 2015 at 1:54pm
I picked up a Simplicity 8 horse walk behind tractor yesterday that was owned by a friend who passed away over a year ago.  His widow finally decided she would never use it but hated to lose something her husband enjoyed.  It has set outside for almost two years.  I brought it in the shop and messed around with it a bit, pulled the spark plug and turned it over, no spark.  took the cover off the points and they didn't look real clean so took them off and filed them a bit.  Putting them back on I may have messed up the gap adjustment screw as it looks like the nut is broken from the rest of the brass piece between the points and engine block.  How are the points adjusted?  I cranked it over (rope starter) several times but couldn't see a spark either at the points or plug.  Any ideas? Thanks in advance.
Allis Express participant
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 5:37pm
be sure to clean the flywheel magnets and the coil legs too!---coil ,condenser, and points may be bad!
I run into that a lot on these engines! thanks; ac fleet
This page was generated in 0.128 seconds.
