Allis B Ring Gear Question
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Ring Gear Question
    Posted: 22 Dec 2015 at 7:44am
So my B is pretty much made of spare parts we had lying around the farm from many different machines. It is a 1944 rear end so it has the starter opening in the torque tube but the only flywheel I had was from a hand start combine power unit so it doesn't have a ring gear and I also don't have a starter for it so I have always just hand started it. However I recently found a loader for it and I would like to do a live crankshaft pump for the hydraulics and therefore thought about finally make it electric start.
Now the actual question: Are the ring gears that you can buy for a B compatible with a hand start flywheel (can I just put a press fit ring gear on the combine flywheel)? Or, do I need to get a different flywheel that was designed for a ring gear from the start?
Edited by cpg - 22 Dec 2015 at 7:44am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:22am
None of the flywheels that I have are. that does not mean that no crank start tractors of later years were not. I do not know how far away from me your are but I have a stack of flywheels in the shed that have bad ring gears on them. I am just South of the Michigan line at the Indiana line. I could meet at the Turn Pike mid toll at Ohio 49. I don't sell parts but will take anything in trade that you think would be worth what a used flywheel would be worth. Don't be shy, I said (anything)  I received a quart of home made pickles one time for a part. Another time I received a can of smoked salmon. Smile All trades leave me with a fun memory story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:22am
I don't know about the BE engine, but the early hand start W engines had a different flywheel that wasn't turned to accept the ring gear.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:33am
I would not want a loader on a B. There is no reinforcement from the front end support to the torque tube at the rear engine mount like on a D14/15.  I had one that broke the lower rear engine mounts.
Also the B has a weak steering box that would not last long with the extra loads on the front end.
Just my opinion.
Bill B
