WC puller build
JoshL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshL Quote  Post ReplyReply Direct Link To This Post Topic: WC puller build
    Posted: 21 Dec 2015 at 1:31pm
I am building a WC with a gleaner block. Going to a 6 inch stroke and possibly a 4.5 or 4.25 bore. I can't decide between the piston size. I am going to be pulling NATPA 2T. I already have a head with 2.125 intake and 1.625 exhaust. Carb and Manifold have been worked on too. Would I have enough power with the 4.25 bore??
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 4:21pm
At least 4.5
alchpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alchpuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 10:10am
If you go bigger than 4.3 the stock head gasket won`t work, for top cut
3 mph the 4.25 will be plenty of power,your valve size, the exhaust side
is really not that bad, the intake side, it will take a lot of work to get that big of valve to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 10:17am
What connecting rods are you using for the 6 inch stroke??
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 4:40pm
Having Marty build me a set
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 4:41pm
I thought stock gasket would work up to 4.5?
