Question Dr.Allis |
Mike NEIN
Joined: 15 Jan 2010 Location: Rome City, IN Points: 405 |
Topic: Question Dr.AllisPosted: 27 Apr 2010 at 8:53pm |
We have an xt 190 series 3 with 200 hrs on overhaul and when you start pulling it down it starts smoking like a freight train and falls flat on it's face. It sounds like it's flooding out like a gasser when you pull out the choke. We put new injectors in when we overhauled it.When it's idling the fumes out the exhaust will choke a horse. would it be the pump or bad turbo? Thanks, Mike.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 27 Apr 2010 at 9:34pm |
How's the air filter? Could be starving for air.
DrAllis
Posted: 27 Apr 2010 at 9:39pm |
So it's done this for 200 hrs????? sounds like turbo or bad air leak, but the smoke at an idle isn't that.... a boost gauge reading would tell us something.....XT series 3 should have an AirResearch turbo.? |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3547 |
Posted: 28 Apr 2010 at 7:37pm |
what is the timing - sounds retarded , bump it up 2 degrees at a time. Also check the intake manifold for a plug missing thus dumping boost.
Mike NEIN
Posted: 28 Apr 2010 at 9:24pm |
Thanks guys just got in from drilling beans. when it rains I'll put a gauge on it and see what we have, and then play with the timing. Could they have put the wrong tips on the injectors? Because it didn't do this before we overhauled it. Thanks again to everybody.
