Any interest in a project WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Any interest in a project WD?
    Posted: 27 Apr 2010 at 8:12pm
This weekend I brought home a WD, that I thought for sure would be a parts tractor, as it has been sitting outside for some time.  Tonite I got to tinker with it for the first time.  Put a pipe wrench on the hand crank as I couldn't find my hand crank lever, and it didn't want to turn but with a little bit of a pull, she popped free and cranks over good by hand.  Front tires are good, rear are matched, dry cracked but ok.  Rear fenders are all beat up.   Front tin is good.  Tractor is complete with starter, generator, and distributor conversion.  I don't think it would take too much to get it going.   The only bad things I see on it, is the blocked is cracked behind the carb, and repaired and not leaking.  Also throttle quadrant is broke on hyd. lever side, but piece is there so it could be repaired.  Fan blade rubs on shroud on side of radiator, so that will need to be addressed.  Also eccentric bolts are buggered up and a bigger nut is welded over them.  Gas tank looks clean.   I haven't done anything to it, other then bring it home and see if it was free.  It will need some work, but I hate to part out a tractor that with some work, will be a good runner again.  I don't want to sell it just to have someone else part it out.   It would be nice to sell it as a 4H project or a project for some young kid who is looking for the right project to get into tractors.  I am going to post it on here, as well as YT and craigslist.  If I don't get any interest, I will start to tinker on it and see if I can get it going but if I do, then I will try to sell again but for whatever else in parts I had to stick into it.  As it sits right now, I would like to get $400 for it, which I think is more then fair considering what scrap is at, and we all know it's worth way more then that if I part it out.  I just don't have the heart to do it to this one, as the guy who owned it that passed away, this tractor was his fathers first tractor on the farm and was the only tractor for many years.    Here is one picture of it.  Email me or PM me with any interest.
boergoatfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boergoatfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:03pm
how much to bring to ohio??
Raising tunis sheep and oberhasli dairy goats and driving my allis chalmers tractors... Life is great
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:06pm
if you were closer to PA I'd be all over it
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:21pm
Looks like a deal!
A little hard on the trailer fenders, aren't you Chuck????
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 6:06am
Yea, Adam they came getting more and more dinged up.  I found replacement fenders for 20 a side, but then I would feel bad the first ding they get.  These are just thin metal.  I was thinking of bending a piece of rebar and welded it to the front for strength.  I don't have any reason to drive to OH.  Maybe someone is coming that way empty and can haul for cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 12:40pm
Ever make it to Iowa like Des Moines or Waterloo?
Edited by Brian Jasper co. Ia - 28 Apr 2010 at 12:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 1:37pm
Adam, Them fenders look like mine. I had a guy loading my trailer with a JD skid loader with a grapple. He did it for free so I had to bite my lip. This is what he was putting on the trailer. I got ten loads from him.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 5:27pm
Brian, I sent you a PM.  Chuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:23pm
bump
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:31pm
Ever make it towards the western UP of Michigan?
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:33pm
If you come to PA let me know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 4:44pm
Tractor is sold pending receiving check.  Thanks for the interest.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 4:48pm
hmm if i had known you take a check i would have bought it days ago. i have a canceled one right here ready to mail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 5:07pm
Well, we all know checks are only worth the paper they are written on.  Once the check clears, she can go away home to the new owner.  I'm not the sharpest tool in the shed, but definately not the dullest either!!
