Information on 1948 WD with mounted plow |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Topic: Information on 1948 WD with mounted plowPosted: 15 Dec 2015 at 4:47pm |
Our neighbour had an early row crop WD that was equipped with a 3 bottom hyd plow.
There was a frame that was mounted under the tractor with a pin connecting frame to the tractor were the snap couple attachment was connected when the s/c came out in the mid 50's. The plow was attached to this frame. Does anyone recall seeing a plow like this. believe there was a chain on each side from the frame that was attached to each lift arm. Dick would plow all day long running the engine at 1/4 throttle and the governor would keep kicking in. |
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Posted: 15 Dec 2015 at 9:31pm |
I think you are talking about a "pin Hitch". that is what I get from your description, if I am right I have 2 of them.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 16 Dec 2015 at 9:58am |
WD45
Posted: 17 Dec 2015 at 7:52pm |
The plow that Dick had was before this set up. Chains were used on each side from the plow to the lift arms and there was a large coil spring ahead of were the pin went in (were snap coupler would connect).
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 18 Dec 2015 at 7:17am |
Are you talking about something like this? Look at GrayRay's WD pic just a short ways down.
OOPS.....forgot the URL http://www.allischalmers.com/forum/forum_posts.asp?TID=113705&title=whats-your-pride-and-joy-tractor Edited by Ted J - 18 Dec 2015 at 7:18am |
WD45
Posted: 18 Dec 2015 at 7:32am |
Yes , that is the spring.
CTuckerNWIL
Posted: 18 Dec 2015 at 10:08am |
That spring was common on WD's with plows up till the SC set-up anyway.
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 553 |
Posted: 10 Apr 2019 at 7:05am |
My memory is a little vague but grew up with both and I'd say the answer is yes. We started with 2-16's with the drawbar pull and later with 3-14's pin hitch pull. With the first the drawbar has to float up and down and remember more than likely the pto shaft has to come out with both.
DougS
Posted: 10 Apr 2019 at 7:20am |
We ran a '49 WD with hitch pull. The PTO shaft didn't need to come out. The hitch pull was a little more complicated to hitch up, but it was a rock solid connection.
Brian G. NY
Posted: 10 Apr 2019 at 11:17am |
Some people call this the "beehive" spring. It was an option when ordering the plows. I would guess it was used for the drawbar mounted plow on this particular tractor since it has neither the pin hitch nor the snap-coupler bell.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 10 Apr 2019 at 12:10pm |
I have a 2 bottom and a 3 bottom pin type. also a 3 bottom snap coupler type and a 4- bottom semi mount for a WD-45.
