Allis 620 720 front PTO with Briggs swap
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: Allis 620 720 front PTO with Briggs swap
    Posted: 15 Dec 2015 at 9:57am
My 620 has a generator type onan in it without the front PTO.  I've been kicking around doing the briggs swap.  Can you all tell me if there is an aftermarket front PTO I could bolt up to the briggs if I go that route?
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 8:36am
Or would anybody be so kind to measure their clutch?
Need:
Height of the clutch assembly
DIA of pulley
Belt width
Thanks
Edited by structures - 16 Dec 2015 at 8:36am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 7:21pm
clutch part oregon# 33-188 or warner # 5218-110                                                          1 1/8 shaft  pulley  6 1/4  for 5/8 belt     makes  up for a perfect match to the onan pulley        stub shaft B&S #842655        muffler B&S #808911                         this is what we used on a 720 two years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 7:25pm
stub shaft will be used on flywheel side with oem  clutch pulley drilled out and brouched
This page was generated in 0.097 seconds.
