Another G question
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Another G question
    Posted: 27 Apr 2010 at 5:47pm
I noticed since I have had the G running it seems to peg the oil pressure gauge. Yesterday I swapped out the original Allis gauge for a black faced 30 PSI gauge and started her up. It pretty much pegs the 30 PSI gauge. Is this an indication of something needing attention? I am used to the Allis built engines running 6-12psi and don't know much about this little engine yet.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 5:58pm
According to the specs in the dealer service manual oil pressure is specified at a minimum of 7 lbs and a max of 20 lbs. Ideal is 15-20 lbs. The pressure can be adjusted at the pressure relief valve which is located on the left front (crank end) of the block towards the top. Looks like a large slot head screw in the manual.
