L3
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: L3
    Posted: 14 Dec 2015 at 1:47pm
I am looking at a L3 combine. It has been sitting for a year and the hydraulic pump quit working when it was parked. What things should I look for on one of these?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 2:16pm
raddle chains and sprockets and floors....... of course all chains and sprockets. Leading edge of cylinder bars should be not be rounded. Rubber shoe bushings. Also rubber bushings for the walker pan. Check walker pan for breaks and check walkers for missing chunks. Especially the front of the walkers. If you want to use it on corn make sure it has the wire inserts in the walkers. Check walker wood bushings and check if combine side flexes when the walkers are turning over. Bent crank if it does. All auger flighting and auger trough bottoms. Make sure hydro can climb a hill. Check engine oil for water. Look at cleaning fan and bearings. There's more I'm missing
Edited by Lonn - 14 Dec 2015 at 2:17pm
Wink
I am a Russian Bot
This page was generated in 0.035 seconds.
