H3 Loader Arms
wlhageman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlhageman Quote  Post ReplyReply Direct Link To This Post Topic: H3 Loader Arms
    Posted: 13 Dec 2015 at 1:58pm
Hello,
I picked up a H3 last Year with a loader. Someone has modified the loader arms to 2" x 4" Square tubing and mounted the bucket cylinders on top of the main boom arms. Their geometry is all wrong as the bucket will not Curl back when booms are down and not dump completely when raised. Dose anybody out there have the main boom and bucket linkage from a parts machine?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 2:19am
I have a parts machine, one main arm has been repaired. Have 2 excellent bucket cylinders, main cylinders are sold.
ALLIS EXPRESS!
This year:
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 7:08am
Don't know where your at but theres a big salvage yard in versailes, missori called Zimmermans. You can find him on the net. Usually not to cheap but I suspect he has one in his yard. I know he does ship . norm
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:03am
we have a set 9893792721
Hercules222 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hercules222 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 9:13pm
Sorry to bring this thread back from the dead, but I just bought the crawler from the OP. I am planning on rebuilding the loader this winter, and was wondering if someone could give the the dimensions of the original main loader arms. I assume they were solid steel somewhere around 1.25" thick, but the width is hard to guess. Thanks in advance for any help!
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:17pm
Mine is a 1961 with a loader bucket. The main arms are 1 1/2" X 5".
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hercules222 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:42pm
Thanks! I beefed it up for now with some 3/8x4 flat welded along side, and one extra 4x4 cross member. That helped a lot, but I am still planning on building new arms once winter sets in. I am too busy right now using it to clean up brush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 9:55am
On the HD5G the first units used a square tube for support between loader arms by the attaching point by bucket pins - every one I seen has been repaired or weld cracked at this point.
 Later units used a round tube brace across the area - then a bracket type reinforcement formed onto round tube / then welded in place - have not seen one of those with repairs .
 Might look at this design for that lower end .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hercules222 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 6:36pm
Thanks! I wonder why the round tube holds up better? Must be something to do with the more even stress around the weld. With square tube, there is always more leverage at the corners to start a crack. I was raising the loader yesterday with a half a bucket full of dirt, and something bound up tight and broke one of the main arms, and severely bent the other one, so I will be completely rebuilding the loader. I also bought a 50 ton jack and plan on building a track press so I can turn the pins and bushings. Lots of winter projects!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 10:57pm
On my 715B TLB loader frame they have a large oval material which is welded to the loader arm frame sides . It seems to prevent the twisting - but then I have broken each side during use in below 0 use when doing snow removal - a year or so apart but now matching welds and below the cross brace.
 On them early HD5 I have seen all kinds of braces added and still signs of cracking at welds - that round one - have not seen broken
