badtrack h3
badtrack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Topic: badtrack h3
    Posted: 12 Dec 2015 at 7:56am
I need to remove the track pads and install on better links. Were can I find replacement pad bolts?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 8:59am
When I last purchased what was supposed to be track bolts, the bolts I received were grade 8 bolts of the same length. Track bolts have a slightly larger shank where the go thru the grouser and link. They also have a higher rounded head. The nuts are supposed to be square not hex. Track nuts have been gone for a long long time. If you find real track bolts let me know. For now buy grade bolts and nuts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 11:22am
Track bolts come in size for many machines - length and shank diameter as well as overall size . Any track shop or dealer in Industrial should be able to find what will work .
 For my FD5 the bolts in the split link are 9/16 bolts where rest of track is Metric .
Check with someone like Thill Track and Tractor in Eau Claire WI
 Northern Tractor in Osseo MN , Crawler Welding in Mankato MN
If you have a sample with measurements will help .
http://www.natparts.com/
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 1:07pm
Check out Caterpillar hardware," One safe source"I think is the book with all there bolts and such,and have found it on line. Cat parts are not cheap,but many times the hardware is cheaper and better in many cases than anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 3:49pm
Thanks much. I'll check out the possible sources. I may need to rework the front and rear track rollers. Any guidance on that project?
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 4:01pm
Call Zimmermans in versailes, mo. he has a building full of bolts. Got several for my h4 drive sprockets I needed. Just never know till you call. He has a large dozer salvage yard. Norm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2015 at 5:21pm
Years ago a friend who worked for Cat took me on a tour through the main factory in Peoria, he pointed out a production line making track pads, said they were for JD!
Allis Express participant
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 9:26am
I have used CAT bolts in our HD3.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 1:14pm
Thanks for the tip. Did the cat bolts you found have the shoulder on them like the Allis bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 10:19pm
If you can, get the Caterpillar Fast Moving Parts catalog which lists all Cat hardware and other items as well. The Cat dealers have these  available for their customers. There  are several different styles of track bolts available with shoulders. The bolts that I used worked very well in the AC under carriage links and pads.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 6:41am
Thanks for the cat bolt tip. Have you reworked the track roller bushings? The end rollers feel like the need help on my h3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 6:35pm
The AC track roller uses a Timken tapered roller. Much better than the bronze bushings Cat uses. The front idlers may need to be built up also.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2016 at 6:41am
T340 IH uses the same pad bolts. They are still sold but expensive.
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2016 at 10:39am
My track guy in Penn Yan, NY got pad bolts for my IH 500 for $.75 per bolt with nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2016 at 10:44am
That's half what I paid! Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2016 at 3:39pm
ACJohn
Who is your track guy in Pen Yan
This page was generated in 0.205 seconds.
