Finally - 720 engine swap-more pictures 12/12/15 |
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Topic: Finally - 720 engine swap-more pictures 12/12/15Posted: 06 Dec 2015 at 6:46pm |
Got the new engine about a month and a half ago and finally getting to the installation in the 720. I decided to put it in this one (of 7) and make it my everyday 720 to use. One side note is that I had a couple of new hour meters from some NOS parts so with the new engine I will have an hour meter starting at 0 hours. Here are some pictures...final pictures a little later.
720 with hood removed and original Ohan engine ![]() removing the old engine ![]() The new engine hanging around...ready to install ![]() new engine sitting in tractor ![]() Edited by den/southern illinoi - 12 Dec 2015 at 8:13pm |
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Posted: 07 Dec 2015 at 7:46am |
Nice!
Robert
1964 D15 Series II |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Posted: 07 Dec 2015 at 2:22pm |
what is the new and whatcha doing with the old?
wsherm
Posted: 07 Dec 2015 at 5:06pm |
You will like the 23HP Briggs. I put the same engine in my 720 about 2 years ago. It has plenty of power and starts very easily. It looks like a Small Engine Warehouse kit you are using. That is what I used also. It went in pretty easy. It is a very tight fit though.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 07 Dec 2015 at 8:17pm |
Looks good Den!! Keep us abreast on the pics! Looks like Prego! Its in there!! LOL!
Nate (OH)
Joined: 12 Sep 2009 Location: Bellevue, Ohio Points: 216 |
Posted: 10 Dec 2015 at 3:41pm |
Is that a 616 frame? (I understand only major difference is the CCKA vs the CCBK). Just never seen a 720 with the solid brake petals.
Posted: 10 Dec 2015 at 9:51pm |
Good eye. Yes that is a 616 frame that had a 720 engine and hood installed. It also had the 616 dash and column cover one it. I just changed out the dash and cover so it will be closer to a 720 Special as it has the single hydraulic control. It does have the 3 point...no rear PTO. Den
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 11 Dec 2015 at 6:12am |
With gasoline prices being what they are the B&S conversion will yield surprising operational savings too. We don't own any of that series A-C but have 4 Case/Ingersoll's with 16-20HP Onans and wow do they suck down the fuel as compared to more modern designs!!
Edited by Butch(OH) - 11 Dec 2015 at 6:12am |
Posted: 12 Dec 2015 at 8:12pm |
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 12 Dec 2015 at 8:44pm |
Boy, that is a neat installation! I'm sure it will be much more fuel efficient.
Sure takes care of the "failure to charge" situation on many of our Onan's.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 12 Dec 2015 at 9:48pm |
Den, let us know how it runs out when you start using it. Tracy
Steve in NJ
Posted: 13 Dec 2015 at 5:47pm |
That is a sweet installation fir' sure! I guess that mounting plate raises the engine up to meet the driveshaft. Pretty slick! Exhaust comes out right where it should be.
structures
Posted: 14 Dec 2015 at 8:57am |
That briggs looks right at home in there.
Robert
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 14 Dec 2015 at 1:13pm |
you are going to just love that engine every thing about it is better what muffler did you use ? did you make that heat shield ? might consider bending up a few extras
Posted: 14 Dec 2015 at 3:55pm |
Thanks for all the good words. Now to answer some questions.
The engine is a 23 HP unit from the Small Engine Warehouse, I think Muncie, Indiana. It is a kit intended to be installed in an Allis 620 or 720. The engine that was removed will be cleaned up, tuned up, spruced up and reinstalled in my loader/backhoe tractor which has some engine problems. That engine will be worked over and go on the shelf for the time being untill I need it in one of the 7 720s that I have. The muffler and heat shield came with the kit and are designed to fit the Briggs engine. As far as installation went...Wiring was fairly simple but we did add a relay for the front electric clutch. The engine is equipped with a relay for the starter so we did not have to install one for it. Had a problem with the front pulley on the electric clutch. When mounted as original, it sat half over the back of the battery tray. We had to actually install the pulley 180 degrees from original which put it right over the center of the slot where the belt drops down to the front mule. We did machine the side as it was not machined. The other problem was the choke and throttle cables. If you run them under the cooler as they were before and brought them up the side of the engine, they were bent too sharp to really work. If you look at the picture of the left had side of the machine, you will see where I left the cables full length as they came, made a open ended keeper to hold them inside the hood and then ran the throttle to the engine as it was designed. The choke is run across the valve cover on a raised block tapped for the clamp that was on the engine to hold down the choke shield. Can't exactly call it a easy drop in but not that hard. If I had to do another, I think that it could easily be done in about 3 or 4 hours. I really won't get to use it until spring unless I put the snow plow on it but then I'm hoping for no snow. Den |
Chief Cockeye
Joined: 13 Jan 2016 Location: Auburn, KS Points: 12 |
Posted: 14 Jan 2016 at 9:21am |
Looks great! Have you experienced any problems with engine/exhaust heat from the new engine on the battery? I had lots of problems with this on my Simplicity 4040 (OEM engine) until I discovered the battery heat shield was missing (I got the tractor when it was less than a year old). Installing a shop-built heat shield solved the problem for me, but it took me a few batteries to figure out I had to do something.
Tracy Martin TN
Posted: 09 Apr 2016 at 3:34pm |
Den, looks great. Have you had a chance to use it? Did you consider the Honda engine? What size were the outputs foe PTO and drive line? Thanks Tracy
Posted: 10 Apr 2016 at 6:51am |
No, I have not really put to any test. Hope to in the next couple of weeks.
The reason I went with the Briggs and not the Honda is because the guys that sold it to me in kit form said that they (their customers) were not having good luck with warranty work on the Honda's but no problem on the Briggs. Den |
coggonobrien
Posted: 11 Apr 2016 at 7:04am |
Looks a lot simpler to get the engine mount bolts in
Posted: 11 Apr 2016 at 8:47am |
Yes it is easier to bolt the engine down but on the last
Onan that we put in, we welded a rod across the top of the bolts (the one on the front right needed a bend down as it would not hit the main casting) that went up against the engine casting so we did not have to get a holding wrench on it. We put the 3 bolts in the engine holes before lowering into tractor. We guided it in so the bolts dropped into the mounting holes. Then it was just a matter of installing the nuts and washers. Did it totally from the bottom. The worst it would be is someone on top with a rod to hold the bolts down until the nuts were installed but on this first effort, did not even need that. By the way, in case someone was wondering, the fourth mounting bolts goes into a tapped hole on the engine base. Den |
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 11 Apr 2016 at 9:17am |
Like the installation, looks like it was made for it. I do however have a question about the exhaust. Wondering if the heat shield would actually force more heat onto battery way it is made? I'm sure with 7 of these tractors you've encountered all sorts of issues
over time
Posted: 11 Apr 2016 at 3:26pm |
I have not noticed any effect of heat on the battery but most of my mowing, whatever, does not last very long. I have looked in the parts book and they do show a heat shield over the battery but in the 10 or 11 720s, 620s, 616s,and simplicity models I have had anything to do with...there has never been a battery heat shield on any of them. I have be looking to devise some type of heat shield that would be fairly universal. The problem being that the original battery hookup was side mount and most of them now are poles on top so a shield cannot be laid or however on top of the battery.
Den |
ac720nut
Posted: 12 Apr 2016 at 4:30am |
That's strange because now you mention I've not seen one either, would have to have a air space between battery and shield, been going to build for mine just haven't gotten around to it. Just the way it's designed looks like it would force heat that way. Someday ya get em all lined up would love to see all seven together, like the tricycle front.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 12 Apr 2016 at 12:37pm |
Den you're going to be shocked at how little gas this thing uses. More or less the same engine I have in mine and I can mow close to 15A between fill ups. You will have to adjust the valves a little more often, but it's no problem. You've got a nice piece of equipment there. Leon R Cmo
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 17 Apr 2016 at 12:15am |
A year or two ago I bought a 720 that had that Briggs engine in it. The chock cable came out bast the oil cooler like yours but it turns up to the carb and curved way out to the left, and did not work very well. I fabed an assembly that allowed the cable to go straight up into the assembly and turn a square corner to the carb. works much better now.
Dusty
