AC180 Fuses
1971AC180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1971AC180 Quote  Post ReplyReply Direct Link To This Post Topic: AC180 Fuses
    Posted: 05 Dec 2015 at 7:55pm
I am starting to repair an old AC 180 tractor that has been sitting in the barn since we bought this farm 8 years ago. The tractor runs but no lights or gauges work. The fuse holders were both in bad shape and had no fuses in them. I replaced the fuse holders with new ones but no where can I find what size fuse to use. I had some 7.5A fuses but when I turned on all the lights, it blew. Does anyone know what the correct size fuse to use for the gauges and what size to use for the lights? Thanks.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 8:24pm
I believe my 190 uses 20 amp for the lighting, if I remember correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 9:56pm
I believe you remembered right.  MACK
This page was generated in 0.050 seconds.
