WD Brakes
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Topic: WD Brakes
    Posted: 05 Dec 2015 at 3:08pm
I'm putting new brake pads on a WD. I'm having trouble removing the bottom pin on the housing where the brakes poviot. I've looked in the hole at the bottom the rear housing and the rod is rusty. Should I heat with a torch and try to loosen the rod? Any other ideas? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 3:32pm
You can click here it has been discussed before. I hope this helps you some.
Pastor mike
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 3:33pm
The WD/WD45 brake pins are the most notorious job on any Allis tractor, do a forum search for WD brake pin and you will find several pages of tips and tricks. May take one or a combination of methods to get them out, but all require PATIENCE. Good luck!
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 11:37pm
After you get them out, make sure you use anti-seize on the pins when you put them back in. You grandson (or whoever) will thank you in fifty years when he does the brakes next time.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2015 at 8:22am
Thanks for all the great information and advice! Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2015 at 10:49am
Got access to a welder? When I did my brakes, I welded a bolt to the head of the pins then slipped a piece of pipe over the bolts with a few washers and pulled the pins. Worked very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2015 at 3:40pm
Now that is a GOOD idea!!  Thanks Brian!!!
powerwagon78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powerwagon78 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2015 at 7:58pm
We did that on mine too, welded a nut to the head of the pin so we could spin it and then try to work it out.  Some people will tell you to cut them out and buy new, but I think if you have enough patience you can get them out, but it is a huge pain in the arse...they rust to the housing and to the brake shoes both, so you will need to get it loose from both...
Jeremy
Allis Chalmers WD45 NF
Hesston PT10 Hay Mower
New Holland 269 Square Baler
Semper Fi
USMC 2001-2005 OIF I VET
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 7:14am
They sell stainless pins now. I would recommend you replace with stainless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 6:26pm
Heated up the first one, came out in a few minutes. The second one, worked all afternoon and won't budge. If you cut the pin, how did get it out? Tomorrow I'll try Brian's idea.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 6:43pm
Read above link, but short answer is you cut about 1/2 inch piece out then drive pin in and cut again,till outside half is gone. Inside piece will usually come right out. Be carefull not to cut shoe ears. Read the links above !!!    Mark
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 8:36pm
b26240,have had to remove several of them that way.have yet to find the inner pin seized up,....plasma cutter works great.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2015 at 6:36am
j.w.    I have done 5 brake jobes on these and one of them I did have a little trouble with the inner piece of the pin. I try to just take the pin out by soaking for several days with pb or similar then prying twisting and pulling and if they won't come out after a reasonable time I go right to the tourch. The last one I did for a fellow he had messed with it for about two weeks getting nowhere, I told him I would do the job for $400 pluss parts and he didn't hesitate as he thot it was hopless at that point. As I have said several times before on here I think this is can be the hardest repair job on one of these tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2015 at 8:52pm
26240.you did not rip the man off,those brake pins can be a real challeng.i think allis must have put the anchor pin in the middle of the assy.line and said.....LETS SEE HOW DIFFICULT WE CAN MAKE THIS REPAIR.....
This page was generated in 0.313 seconds.
