Allis G Broken Rear Axle
matthewmscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Broken Rear Axle
    Posted: 26 Apr 2010 at 9:13pm
I have a Model G and have just snapped the rear axle. Does anyone know where i might find a replacement? Also any pointers on this repair would be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 10:09pm
I think I have sourced the axle. I have the service manual. (Thanks to this forum!) After disassembling the broken side i discovered that the splined end that is in the diff. is what snapped off. The broken piece is still in the diff. Does anyone have any thoughts on how one might get this part out? I am thinking of removing the other side ( axle, housing, etc.) and trying to push the stub of the broken axle out the other side. Any thoughts?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 10:33pm
Small cylindrical magnet? Drill a hole and run in a self tapping screw or tap it for a standard thread to give something to grab and pull? Stick a welding rod to the stub though that might stick the splines. Dentil pick on the outside of a spline? Maybe a couple? Drill two holes and use medical forceps or needle nose pliers to pull? Tap the housing with a hammer and shake it out, or tilt it and tap to shake it out?
Gerald J.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 8:35pm
I broke one on my G a few years ago. I got a new one, not used, from a salvage company. It appeared to have work hardened and shattered.
I don't remember having any trouble getting the broken parts out of the differential. The big problem I had was getting the brake drum off the broken axel. It is a press fit with a very large Woodworth  Key in it. I made a puller and used a torch and it would not come off. I finally cut the axel off inside the drum with a cutoff wheel in my die grinder and then bored the axel until it collapsed inside the drum. And then did the same thing at the wheel bearing. I've heard since that most just destroy the drum and put a new one on.
Good Luck,
Dusty
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 8:39pm
  we have used axles   1-800-254-3116   location???
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:02pm
Go to any farm supply store that carries livestock supplies and purchase a cow rumen magnet, tape it to a wooden dowel and you will be able to pull the broken axel stub out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:39pm
Still working on removing the sheared stub from the differential. I guess when it sheared it flared out a bit and it will not easily slide out by use of a magnet or any easy way. I had to take the other axle off and am having to ram it out with a punch from the back side. Almost had it out but my punch bent. I am having to make a new punch and try again tomorrow.
I have located an axle and it is on it's way. (thankful)
I managed to beat the longer portion of the broken axle out of the brake drum. Key in tact. i have not been able to remove the bearing from the end of the axle yet but will try somethings tomorrow. I am thinking about looking for a shop that has a bearing separator that might be able to pull it for me and press it onto the new axle.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:50pm
Matt, remember that there is a pressed on collar holding the bearing on the axle
if you need it
Bearing - 6008rsj
inner seal at brake assy - NAPA 11800
outer seal at bearing- National 450076 or NAPA #17484
if you mess up the collar, it's a AGCO supplied part - 70800165
SandyLake has them & I think Norm keeps them too
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:51pm
Matt, Heat the shrink collar a little. Turn it upside down and whack it on something solid. It will come off then. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:54pm
MAN! You guys are great. This is certainly the most supportive forum around.
Hopefully I will not need the new seals or bearing but it is good to know where to get the stuff if I do. I will try the heat as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:57pm
By the way, who or what is SandyLake and Norm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 10:37pm
Sandy Lake Implement is a long time AC dealer having a tiff with AGCO about new equipment but continuing to sell AC parts with considerable emphasis on vintage parts. A fine source and one of the sponsors of this forum.
Norm is another fine source of vintage AC parts, also a sponsor of this forum.
Check out the vendor's list and recent posts from and about Sandy Lake Implement.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewmscott Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 10:54pm
Norm,
Sorry I missed your post. I am in Asheville, NC. Can you send me the info on your axles just in case the one i found falls through. Thanks.
Ksutton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ksutton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 4:22pm
I am in the process of putting the rear axle on my G back into its housing. I am wondering if the rear axle collar is the same as the bearing clamp ring? I am a little confused by the drawing in the service manual. Thanks.
This page was generated in 0.207 seconds.
