hypothetical tactics question
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: hypothetical tactics question
    Posted: 03 Dec 2015 at 2:06pm
here's a hypothetical strategy/tactics question, simplified for discussion, but not that far from the real deal.  what would you do?
you are at a pull with a weight transfer sled.  speed limit is 6 MPH.
you have a choice of which gear to pull in:
1.  2nd gear, run wide open, tractor will run 6 MPH, or
2.  3rd gear, at about 75% RPM tractor will run 6 MPH.
Do you run in 2nd, so you have the advantage of the lower gear ratio at the end of the pull as the weight box goes up?  or.....do you run in 3rd gear, so you have some more throttle to work with at the end of the  pull??  lets assume that its a middle of the road track, not a real grabbing power track.
If ignorance is bliss, than happy days are here again.
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 2:59pm
On a mid way track like you are talking about I would run 3rd. If you start to spin a little you could idle up to maintain the desired 6mph. If you go with 2nd and start to slip you have no more throttle and lose forward momentum and spin out faster.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 4:00pm
Big pulley
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 5:31pm
3rd as long as you have the power to increase engine rpms when your tires start slipping.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 5:14am
3rd, 2nd on a hard hooking track for me
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 0.073 seconds.
