FS: hubs and steel wheels
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: FS: hubs and steel wheels
    Posted: 02 Dec 2015 at 4:42pm
I have a set of 9 bolt hubs off of a 190xt series III also steel wheels. Thought some of you pullers might need these. 750 bucks. Includes the tires on them. Central IL. 750.00 I will be at Gordyville and Murfreesboro and Louisville if that helps.
                         IG
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 9:23pm
sent you a PM
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 7:17am
Dang John, I might need these, or a set like them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 7:53pm
Bump
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 8:05pm
are theese for 3.25 axles
phil
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 8:39pm
Yes them.are 3.25 in axles
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 8:45pm
What size tires are they?
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 12:15pm
I have 2 sets. One is 18.4 x 34 the others are 18.4 x 38
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 3:25pm
Ok, I need a set of 16.9-38s
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:35pm
So you are wanting a 14" rim ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 9:30pm
I just need the tires, I've already got rims
This page was generated in 0.127 seconds.
