M Crawler ?
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: M Crawler ?
    Posted: 30 Nov 2015 at 7:25pm
Guys: Did the M Crawler use a 6" pitch track chain?
Also, I checked around a bit and could not find any info on the Dimensions for the PINs and Bushings.
Any help would be much appreciated.
Thank - You...
Orangeman
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 9:52pm
Parts book shows the bushings are 1-3/4" diameter. Pins are 5-7/8" long except the master is 6-1/8" long. I don't know what the pitch of the track means?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 4:19am
Hi MNLonnie:  Pitch is the original new measurement from Centerline of Pin to Centerline of Pin.
So the outside diameter of the bushing is 1-3/4"- is there a dimension for the inside diameter of the bushing or the OD of the PIN?
Thanks for the good insights Lonnie....
Orangeman...StarBig smile
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:47pm
Leesok: - Perfect - appreciate the excellent information.  That explains everything that I was researching.
Thanks very much!
Orangeman
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 2:36pm
Any one spot the mistake on the spec sheet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 4:37pm
The speeds are screwed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 7:41pm
The spec sheet is from this book.
It list and gives specs for their tractors, crawlers, plows and implements available in 1935. Specs would be for 35 and prior models. It also has the Rumely 6 and AC Rumely thrashers and combines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 4:04pm
Leesok- Thanks for posting the publication!  It is appreciated....
Orangeman
This page was generated in 0.423 seconds.
