F2 Bin Capacity Question
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: F2 Bin Capacity Question
    Posted: 29 Nov 2015 at 8:23pm
Got the combine to start shelling corn well.  Thank you to all who helped with my last post.  I still have a few bugs in the system, but overall I am pleased.  I finished a field today, and have been doing paperwork tonight for yield reporting.  I looked in the Manual for the F2, and it shows a capacity of 120bu with extensions.  I was curious if mine has extensions, or if it is standard capacity.  Looking online, I see pics with different toppers above what I have.  Mine has two fold up flaps on the front and rear of the upper box, that are held with large rods across the bin.  Some pics have larger boxes going up where I have the flaps.
This picture is from a while ago.
Thanks for helping.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2015 at 8:30pm
John I believe the extension is the box setting on top of actual bin.Most have it but looks like std equipment was just the bin with something like a 16in shorter elevator.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2015 at 10:33pm
In 1978, a shelled bushel of corn weighed 56.67 lbs at 15.5% moisture. Today, it's measured at 56 lbs at 15.0%. I think gleaner must have rated its grain tank capacity based on shelled corn with a 56.67 pound per bushel test weight? Reason I say that, is because today I never get close to gleaner's spec capacity on corn or soybeans. But soybeans have a 60 pound per bushel test weight. So gleaner's 1978 120 corn bushels at 56.67 lb test weight corn equals 6800 lbs. This figures reduces to 6720 lbs at 15.0%. Theses volume weights would only equal 113-112 bu of soybeans. To complicate it further, different harvested grain moistures play an additional weight role.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2015 at 11:07pm
Here's a picture of my father's F3 that has the extensions. Looks like yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 6:33am
DanD,
Thats the look.  So 120Bu is the magic number then
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:30am
Just like mine and soybeans it only holds 105 bu. If you worked and filled the corners you might get 110 bu.  MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 9:42am
yup 120 , like all mfgs, is the 'theoretical' capacity. It is obtainable
buy hand filling every kernel.... 110-112 is about the 'practical' capacity. "cab rain" occurs about 10 bu before theoretical capacity is obtained...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 10:50am
tbran,
Cab Rain.  Never heard that before.  I always called it "oh Sh##" Out of room"
Thanks for all of the information everyone provided.
John
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 7:02am
The capacity rating is based on wheat not corn and I believe all combine manufactures in the US base their ratings on wheat.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 11:55am
I did not know that. Thanks, I learned something today.
