12v conversion kit
kblank05 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Topic: 12v conversion kit
    Posted: 25 Apr 2010 at 10:24pm
does anyone offer a 12v conversion kit for allis c's  i need to buy 4 maybe 5 kits
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 10:40pm
here is a bracket i built to fit the original generator bolts. I use the CS 130 style alternator. THE Dellco 10SI is more common, but somewhat bigger in diameter. The oother problem is the tensioner on the top. You got to built a L bracket similar to the ggenerator one.  Im not sure, but i thought Steve at B&B was going to make a kit ssomeday.  Here is an idea if you want to build your own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 3:31pm
that does help but i was hoping to find someone that had the whole kits with instructions, im not verry good at wiring  and i know 6v isnt getting the job done. thanks
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 6:44pm
 Steve  at  B n B has complete  kits,  with  instructions.  1-973-632-5596  Tony
This page was generated in 0.057 seconds.
