Opinions on Simplicity built lawn mowers
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Opinions on Simplicity built lawn mowers
    Posted: 25 Apr 2010 at 9:09pm
We have a Ranch King Lawn mower and I really like the way it mows.  Very nice smooth finish.  Lately the tranny has started to act up and we are looking at replacing it.  A local mower shop has a 4212 Simplicity and a 5216 simplicity (both hydros) on his lot.  I have also found a 1976 710 Allis lawnmower for sale locally as well (although the owner says it is a 16 hp kohler instead of a 10 like simpletractors.com says it should be).   What are everybodys opinions on these mowers?  I always liked the single cylinder briggs engines like the 4212 has, but the 5216 has a 16 hp briggs twin cylinder opposed engine which to date I haven't had good luck with (could have had a bad engine though).  The 710 looks ideal to me, just I haven't got a chance to look at it yet.  What is everybodys opinion on how they mow?  I used my uncles newer (1992 style) Simplicity Landlord and it does a terrible job of mowing in my opinion, but the deck seems wore out and the small deck wheels are wore out to non existant to flat on one side.
Thanks for any opinions
Adam
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:15pm
I SOLD SIMPLICITY FOR YEARS THAT 4212 WAS THE BEST MOWER THEY MADE(MY OPINION) VERY SIMPLE AND VERY EASY TO WORK ON. I MAY HAVE SOME PARTS LEFT AND A SERVICE MANUAL. I AM PRETTY SURE I STILL HAVE A OWNERS MANUAL IF YOU WOULD NEED ONE
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:24pm
Is the 16 HP twin a Vanguard series,(V-twin) or "boxer"-style(180 degree opposed)? I have a 16 HP Briggs twin-2. It has been running since 1986 with only one burned out head gasket replaced since new. No other internal repairs have been made. Very few other repairs to engine. Occasional carb rebuild needed. Had to replace the charging system stator and regulator unit 3 years ago, that's it. Still has decent power, no oil cumsumption problems. Did I mention it still mows over 2 acres at my place, and almost that much at my sons' place, and that's the least it has been used since it was new. Tractor has been a good one too. Snapper YT-16, 42" cut. Replace deck spindles periodically, mower belt every 3 or 4 years. No other major repairs. Did weld a band of 1/4" x 3" plate all the way around the deck. Good engine, good machine. I have a 16 HP V-twin on another machine. The overhead valve engine gives quicker power than the boxer, but it is not nearly as trouble-free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:26pm
My dad has two of the AC garden tractors which are the same, just different badge.  I think a 718, and a 916.   I just picked up two of them today as well.  In my opinion, the older Simplicity garden tractors were built to last.   Many of them have cut more of their fair share of grass and they still are kicking around.  I would think if you found a good one that was taken care of, it will last you easily the rest of your lifetime.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:26pm
I bought a new 1616H AGCO in 1996 and it's been real good to me and can really go through grass compared to Cub Cadet. Doesn't compare to some of the commercial front cuts but it does good. It's mowed a couple acres from 1996 until about 2007 when I got a C with a Woods. I replaced one belt and the PTO switch and that's it. Now I just mainly trim with it.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:32pm
Dream,
It would be the 180 degree engine.  "Boxer" I guess your calling it.  Seemed like the carb always gave fits on dads Yard Machine.  Father in Law also has one in another MTD mower and the carb is giving fits on it too.
Adam
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 9:49pm
Make sure you have a fuel shut-off on those 2 cyl engines, that may help out your carb problems.
