Wanted: D17D Pushrod
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: D17D Pushrod
    Posted: 25 Apr 2010 at 6:29pm
Well, got the head off my D17D. It has a bent push rod...as well as some fused debris stuck to the top of #3 piston that was hitting the piston. Head will be going in for an ispection and rebuild, and I will obtain a new piston/ring assy to stick in the #3 hole. Anyone out there have a few good pushrods for a D17D that they could part with?
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 8:08pm
 I got a few...$5 ea, discounts for more than 1 sound fair ? Also have some used pistons....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 7:00am
I have some used pistons and sleeves that are in decent condition.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 7:14am
I have pushrods for a D-17 D, also   a rebuilt set of injectors, ( ran for 2 years), oil pan, oil pump, valve cover, block, crank, rods, cam. $5.00 each  for pushrods. If you need anything let me know. 708-269-9628. (cell)
This page was generated in 0.186 seconds.
