Thin gasket supplier |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Topic: Thin gasket supplierPosted: 20 Nov 2015 at 2:09pm |
I need the really thin gasket paper for my B oil pump. As I understand it, the paper gasket should be around 0.007 inches. The thinnest paper I can find is 0.015 inches. Any suggestions for suppliers of this paper? Or can I use a paper bag or piece of paper?
DougS
Posted: 20 Nov 2015 at 2:43pm |
That's about 3 human hairs. I don't know if wax paper would hold under the heat or not. Parchment paper probably would. I'd think you'd want something that compresses a little.
Hubnut
Posted: 20 Nov 2015 at 3:08pm |
Yeah, I guess it will compress. I'll try the 0.015 and see.
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 20 Nov 2015 at 3:22pm |
You could always get the correct "already made" gasket from Agco. I can still get the hydraulic pump and PTO gear box gaskets for the WD/WD45 from them, so the oil pump gasket for the B/C/CA should be available, I would think. Rick
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 20 Nov 2015 at 4:45pm |
what happens if the gasket is thicker?
SHAMELESS
would blue glue hold?
Hubnut
Posted: 20 Nov 2015 at 5:45pm |
The end play was too great with the 0.015 inch gasket. I got some 0.007 gasket paper and that worked within the specification for end play (0-001-0.003). Thanks for the help.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24890 |
Posted: 20 Nov 2015 at 5:54pm |
I was wondering how thick (thin ??) an aluminum pop can is ? it'd compress a weee bit.
Jay |
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 20 Nov 2015 at 6:52pm |
Will not hold prime! |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 20 Nov 2015 at 8:46pm |
Dad used to call it onion skin paper, not sure if that is a technical term or farm jargon? Every B/C pump I have worked on had enough wear on the end of rotor and blades that the gasket is not needed for clearance. I flat file the case and cover only enough to remove burrs then bolt the cover on without a gasket. if it turns over with no stiffness take the cover off add a THIN bead of silicone bolt it back together and its ready to go.
Edited by Butch(OH) - 20 Nov 2015 at 8:47pm |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 20 Nov 2015 at 10:06pm |
When I bought a C I got several gasket kits and one had multiple thicknesses of gaskets for the oil pumps. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
