I600 swing motor
Aaron(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron(IN) Quote  Post ReplyReply Direct Link To This Post Topic: I600 swing motor
    Posted: 20 Nov 2015 at 11:45am
Has anyone tried to reseal an I600 backhoe swing motor? I have one that is leaking out the top and was thinking would be a good winter project to tackle. Any information would be appreciated.
Thanks,
Aaron(IN)
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 6:49pm
No info except that it is a Cessna and was also used on Massey backhoes. Haven't had an I60 for almost 40 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 8:51pm
I put a kit into mine on the AC 650 hore I have - works great EXCEPT that top seal weeps oil . Was real careful putting it together , it leaked some from bottom before i repaired it , stopped that leak and now top weeps .
 I had a chip out of the rotary piston I had to weld and machine down to get a good internal seal as before hoe would drift easily in direction of swing , got that solved but that top leak - another day project .
 Yes Massy used same Cessna unit on their hoes and you can find those parts easier although the AC parts might be at Minnpar
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 12:31am
It's been 30 years since I had to address that top seal when I had the I600. I seem to remember the seal wanting to lift slightly and then weep. We made a steel ring to hold the seal down, a few spot welds held the ring in place.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 8:10am
We work on hyd pumps and motors all the time where I work. The reason an older pump or motor is so hard to keep from leaking is that everything in most of them runs metal to metal. When they are built they have just enough clearance to let enough oil between the parts for lubrication. Over the years of use the clearances keep getting wider and wider and this lets too much oil get past and it puts too much pressure on the seal. I tell customers if you put a new seal kit in one time and it still leaks it is more than likely worn out.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 9:04am
that top seal is like a inverted V ring seal that is in a recess in the top casting , the top shaft of the rotary piston has little relief on end to slide through seal .
 Wear could be part of the problem -
juliesmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juliesmith Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 4:10am
Not much idea about it.
Daelric View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daelric Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 9:51am
Did you have any luck with this? I have an HD4 with the Industrial 600 backhoe attachment on it, and my rotary swing cylinder recently developed a pretty bad leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 11:41am
I do not use mine that much, but the seals that I got was able to seal it back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daelric Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 12:23pm
That's great! Would you mind sharing exactly what seals you got and where you got them from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daelric Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2022 at 3:57pm
Here's a picture of my unit... Would I be able to just pop the top off to access the seal? Or should the whole thing be removed from the machine and moved to a bench to work on it?
Edited by Daelric - 31 Aug 2022 at 3:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2022 at 11:13am
You can just remove the top sectionn and get to seal , when replacing the unit it's important to be sure seal is not cut or deformed when installing
kleinwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kleinwp Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2022 at 12:06pm
I also would like to know the details about where to get this seal.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Aaron(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 11:19am
It's been a few years.  It was one of the vendors on this site.  I think it was something like Illiparts???   I did some web searching, not sure if they are still in business or not.  They was very helpful in getting what I needed.
Sorry, if I find something more I will post it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2022 at 5:17pm
Illini construction parts, maybe?Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote Daelric Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 2:27pm
I managed to find all the exact, correct parts from Agco! I was only able to figure them out when I found reference to the fact that this model of Cessna swing motor was also used on a Massey Ferguson backhoe, so when you're looking at the Agco parts books you have to look at the right MF model (Massey Ferguson 54A Backhoe).
Anyway, the parts are there, but they aren't cheap. I was only replacing the top seal (not the bottom) so I only needed 3 parts (I'm in Canada, so prices are in Canuck bucks):
Part# 70924143 (o-ring): $4 CAD
Part# 1097135M1 (Seal): $190 CAD
Part# 1031686M1 (Backup washer): $150 CAD
So for the 3 parts I was in for $344 CAD... with shipping it came to around $365.
I've successfully replaced the seal and with a quick test it seems the leak is gone... but I won't know for sure until I do some more heavy digging with it and put the seal under load while the oil is hot.
This page was generated in 0.043 seconds.
